how to change/enable mode pin?
i ever change at “/sys/kerner/debug/pinctr/44e10800# pins”
but output is “invalid argument”
anyone know?
anyone know?
The config-pin utility (which relies on cape-universal) is the
simplest way to configure BeagleBone pins:
https://github.com/cdsteinkuehler/beaglebone-universal-io
How are you planning to use the pins?
-drew
I use it for input/output infrared
Pada tanggal 13 Jan 2017 10.08, “Drew Fustini” <pdp7pdp7@gmail.com> menulis:
I'm afraid that's not enough information for me to help. It would be
helpful if you could post a schematic and a list of the parts that you
are using.
-drew
Example: default pin p8_3 is gmc_ad6 (mode0). I want to change that pin to mode7(gpio1_6)
How to change? I cant solve it…still mode0
Pada tanggal 13 Jan 2017 10.15, “Drew Fustini” <pdp7pdp7@gmail.com> menulis:
It seems that P8_3 is used by the eMMC by default. I am using Debian
8.6 (2016-11-27). When I first tried config-pin for that pin, I got
this error:
debian@beaglebone:~$ config-pin -q P8.3
P8_03 pinmux file not found!
cape-universala overlay not found
run "config-pin overlay cape-universala" to load the cape
I edited /boot/uEnv.txt to use dtb that disables eMMC and enabled
cape-universala:
uname_r=4.4.39-ti-r79
dtb=am335x-boneblack-overlay.dtb
cmdline=coherent_pool=1M quiet cape_universal=enable
cape_enable=bone_capemgr.enable_partno=cape-universala
After rebooting, the cape-universala overlay is loaded:
debian@beaglebone:~$ cat /sys/devices/platform/bone_capemgr/slots
0: PF---- -1
1: PF---- -1
2: PF---- -1
3: PF---- -1
4: P-O-L- 0 Override Board Name,00A0,Override Manuf,cape-universala
P8_3 can now be set in GPIO mode with config-pin:
debian@beaglebone:~$ sudo config-pin -q P8.3
P8_03 Mode: default Direction: in Value: 1
debian@beaglebone:~$ sudo config-pin -l P8.3
default gpio gpio_pu gpio_pd
debian@beaglebone:~$ sudo config-pin P8.3 gpio
P8_03 Mode: gpio Direction: in Value: 1
-drew
If you have questions about what exactly to edit in /boot/uEnv.txt,
then please post the full contents of your /boot/uEnv.txt
-drew
