Has anyone gotten the honeywell HMC5883L 3 axis magnetometer/compass working with the beagleboard? (hopefully the bone).
Eric
Eric
Yes, but I did not use kernel driver, but talked to it directly over i2c.
j.
do you know of a kernel driver for it? can you reference any good code or other references that helped you make use of it? Really wanting to use it as a tilt compensated compass.
Eric
I used the best reference you can get: the datasheet
The chip is quite popular and there is a lot of code floating around
on the net. I think I read about a kernel driver, but never tried to
use it.
To talk to the chip, I use korebot i2c library:
http://ftp.k-team.com/korebot/libkorebot-doc/
j.
Here is one from the GTA04/OpenPhoenux:
