Home Audio Project
James , I think I can answer some of your questions but not all of them yet.
I am doing something similar to you, I am using the beagleboard xm to implement guitar effects,
in my case I am writing a valve amplifier preamp simulation am I am using the method of
electronic circuit simulation.
The beagleboard xm has a TPS65950 codec chip on it which is capable of 48khz sample rate
and 16 bit sample resolution. The beagleboard xm also has a texas instruments 64x fixed point
DSP processor.
I have a working program now where the arm processor reads audio data from the audio capture device
and sends the data to the DSP, the DSP processes the data and then sends the data back to the
arm processor and then the arm processor sends the data to the audio playback device.
I am quite impressed with the performance of the DSP processor when I use fixed point maths
for the calculations but floating point maths is fairly slow.
The biggest problem I am having is the latency introduced by the linux audio driver on the arm processor.
I would guess that I am getting about 50->80 ms of latency which is too much for a real time guitar
effects application because you hear a slight delay between playing a note and then hearing it in
the speakers.
I am using the tidspbridge driver that exists in the linux kernel to communicate between linux and the DSP.
There is a user space library that goes with the tidspbridge driver which I use on the arm processor and
also a framework for building your DSP code using the texas instruments compiler which is a free download.
So I dont have to worry about the code associated with communicating between the two processor, that
code is already written for me , I just have to write the DSP code for my algorithm.
I am investigating the source of the latency in the linux audio driver because I want to see if I can
improve the latency, if I can then I would say that the beagleboard xm is suitable for real time audio
processing but otherwise I would say its just a little bit too slow.
Another possibility would be to investigate some of the other texas instruments evaluation boards
and see if there another board with better specs but I would expect that you would have to buy a
software development kit for the board and it would only run on windows which is unacceptable
for me.
another option is to make the DSP access the audio codec directly, thus avoiding the latency of piping the audio data between ARM and DSP. it involves writing a MsBSP driver for the DSP side, but that should be covered by existing code for TI DSPs...
There are DSP-only boards with codecs, but that setup is close to using the McBSP directly from the DSP on a Beagleboard. Unless you need afloating point DSP which the Beagle does not offer..
should be covered by existing code for TI DSPs…
Hi Vladimir,
That would be a great solution but I dont see how to do this easily with
the dspbios version 5 that I am using. There is an API for the DSP that
comes with dspbios version 5 but it does not cover the things that I would
need to do in the driver. In order for the DSP to read and write audio data
I would need to setup the DMA, the L3 and L4 interconnects, access the
registers on the MCBSP peripheral , access the codec using the i2c bus
and other things. While that is all possible in theory, I think it would be very
difficult to do.
I am quite happy to be corrected, if some one knows an easy way to do it
I would love to know.
Hi Vladimir,
data
would be very
difficult to do.
I don't know if anybody ever did that, but it should be possible McBSP is one of the peripherals that can be mapped to the DSP side.
Also, setting up a DMA on the DSP should be doable...
maybe do I2C setup of the codec on the Linux side for a start...
I don’t know if anybody ever did that, but it should be possible McBSP
Also, setting up a DMA on the DSP should be doable…
maybe do I2C setup of the codec on the Linux side for a start…
Thanks for the encouragement Vladimir but what you are suggesting is a huge project,
I estimate at least 6 man months and even if I did do all that I would still be stuck with the puny
16 bit A/D and D/A converters on the beagleboard xm. You need 24 bit sample accuracy to get
a good quality sound, so my plan is to try and find a low latency USB audio device that is supported
by the linux kernel.
Also. from what I can tell, gstreamer is not a valid option because the focus of gstreamer is not
on latency but on throughput. A digital guitar effects processor has to have good throughput AND
good latency. The gstreamer approach still makes use of the alsa audio driver to capture and playback
audio so it will have the same poor latency that I am experiencing.
    McBSP
huge project,
usb audio will also go through alsa, so you will add usb latency on top of alsa latency, no?
maybe it would make sense to try to reduce alsa latency with the onboard codec as much as possible as a first step since that will be the baseline for all the other solutions
Well, no.
If I can find a low latency USB audio device then my problems are solved.
The problem is not alsa in general, the problem is the alsa driver on the
beagleboard xm. This specific driver has a high latency.
I believe that the reasons for the high latency are the following :
  1. The TPS65950 audio chip is connected to the the DM3730 processor using
    the i2c bus which is inherently a slow interface.
  2. The TPS65950 audio chip is connected to the the MCBSP2 interface of the
    DM3730 processor which has a massive hardware buffer of 5k.
Well, no.
i2c is only used to setup the codec, not for data transfer.
and you are sure that one has to use the full size of that buffer always?
Another thought is to leave the I2C and MCbsp handling on the Linux side, but leave out userspace. kernel would setup MCBSP and DMA into a buffer(s) and DSP would read/write directly from/to that buffer(s)
Yes but what if the driver has to access this bus at a time critical time such as the time
between filling the playback buffer and starting the PCM device. This delay forces
you to specify a larger playback buffer than you actually need just so you can start the
PCM device.
It appears to be always full on the playback side , not always full on the capture side.
A change to the driver should be able to change this behaviour.
delay forces
you can start the
PCM device.
I don't see a problem here, you need I2C to set up stuff like word length, sample rate and volumes, you dont need it during the actual data transfer.
    always?
the capture side.
might be worth a look
Hi Vladimir,
My observation comes from profiling the code and seeing what it actually does
rather than taking guesses at what it should do. Perhaps you can help me
investigate the sources of latency in the alsa driver code by examining and
profiling the code rather than just making a guess.
Scott, I’m obviously new to this hardware, but I was comparing the beagleboard and beagleboard-xm specs and noticed that the xm added a USB hub. It’s not clear to me from your posts if this would be a problem, but it seems like the kind of thing that could add some latency.
I certainly hope it is not the USB hub causing the latency !!!
I hope I didn’t offend Vladimir with my last post, I can see he knows a lot about the OMAP processor and
I guess I got a bit frustrated with all the questions. At this point in time, I don’t truly know what the cause of
the latency is and I have ignored it for now and just focused on the DSP algorithm.
The DSP is certainly not the problem. I am really impressed at how fast it operates.
My algorithm at the moment is a saturation curve. The guitar signal has a constant gain for small signals but
the gain reduces for larger signals. It actually sounds pretty good and the DSP can process 64 samples
in about 300 micro seconds I think is pretty good.
I hope I didn't offend Vladimir with my last post, I can see he knows
not offended at all :slight_smile:
in time, I don't truly know what the cause of
DSP algorithm.
fast it operates.
if you have some code to share, put up a github, I am sure others would like to use the DSP too.
(and I like having some URL to point people at)
I am very interested in this thread.
I’ve been considering using TI OMAP or Sitara processor for a couple of similar projects for some time. One is a potentially pure open-source project The other has some backers hoping to make something they might sell, but who don’t mind if I contribute non-strategic bits back for others.
I share many of the concerns expressed here. I am told that 50 ms end-to-end latency is too much. I am very interested in exploring all of these approaches to mitigate this problem.
I have been very happy so far using a BB-XM for rough prototyping. but I am concerned that I don’t expend a lot of effort on hardware that will not be available at satisfactory volumes for a niche manufacturer. I want to work (if possible) with an ARM CPU tightly coupled to a floating point DSP.
I am concerned that the only product with in the OMAP line that is supported for my purposes seems to be the OMAP L138. Though overall performance of the ARM side is not the main concern, I am worried that its ARM 9 core is a major step down in performance, and wonder what other limitations it may contain that I’m not considering. I want to use the DSP for effects processing, but I need control of the system and ideally drivers to live in some kind of os, preferably Linux
Does anyone know if this latter is a reasonable concern?
I am also wondering if the ‘Programmable Real-Time Unit Subsystem’ (PRUSS) processors can be used to good reduce latency in a McBSP<->PRU<->DMA<->CPU chain on any of these processors?
Dave
