Hostapd failed with USB WiFi dongle (RTL8188CUS 802.11n)
hi, i’m encountring the same problem, did you solve this problem? if yes, how??
I setup ad hoc wifi with RTL8188CUS by following adafruit tutorial (step by step but adapting RTL chip version):
https://learn.adafruit.com/setting-up-a-raspberry-pi-as-a-wifi-access-point/overview
If you use udhcp, you need to disable some part of /opt/scripts/boot/am335x_evm.sh relative to udhcp, and you lost ethernet via USB
Yours,
