I am using USB 200M
What did you try? What problems occured?
Robert
Hi wb,
I'm not sure what kernel you are using. However, if you are building
your own kernel, you want to select
ASIX AX88xxx Based USB 2.0 Ethernet Adapters
in Device Drivers --> Network device support --> USB Network Adapters
Hope that helps.
Cheers,
Jay
I am using kernel binary given http://code.google.com/p/beagleboard/wiki/BeagleSourceCode
Kernel (uImage) 2.6.22.18
Hi wb,
I'm not sure what options were selected in that kernel. However, I
suggest you try to build you own kernel with ASIX support as I
described in my previous post. I have the same USB device and that's
how I got it to work with the android kernels I'm working with.
Cheers,
Jay
Hi Jay
I will try to build kernel from given source.
Can I connect USB to Ethernet directly without using any USB hub. I
have got one hub but that do not have external power supply?
Vikrant
No, you can't connect the USB200M directly to the beagle. I tried to
connect it directly but the board doesn't seem to provide enough power
to power the USB200M. I use a powered hub and it works great with the
Angstrom BeagleBoardDemoImage - no need to build your own config, the
options are already chosen in the openembedded beagleboard-demo-image
build.
Its difficult to get USB hub with external supply in my city in India.
Finally I got one USB hub but its not from any standard company Which
USB driver I should select to build?
How about giving external 5V supply through connected cable and not
using USB hub?
Do I need to short 4&5 pin of OTG connector of Beagle board?
VVB
