How do I create a clock?
I was use vi editer (user space)
GPIO_HIGH();
GPIO_LOW(); ← SO I has used but it is very slow …
So, i want to create clock in BBB
How do I create a CPU clock?
GPIO_HIGH();
which type of clock?
Well, this question is a bit like asking “How do I make a car?”
Sorry Sorry …
I am doing a project using the camera.
but ,The first method is to receive data rate is too slow.
GPIO_HIGH();
GPIO_LOW(); ← Userspace coding
So ,I hope come to read the data a little more quickly.
can someone help me?
2015년 7월 27일 월요일 오전 6시 55분 21초 UTC+9, William Hermans 님의 말:
Video4linux?
Use PRU to read/write I/O pins which can be done in 5ns. I don’t understand how you want read data through GPIO pins from a camera.
thanks for reply
Put the clock in the camera comes out give data.(8bit)
So I made read clk and recived data.
However, the speed of reading data from a GPIO through the mmap was slow to solve the problem, but a problem occurred a slow in clock speed makes the BeagleBoard
So I have such a question.
2015년 7월 28일 화요일 오전 3시 43분 44초 UTC+9, Karteek YV 님의 말:
If you control a GPIO pin from a high level language via the linux-system-file-io, you can toggle the pin at about 6 kHz maximum.
If you control a GPIO pin directly from a language like “C”, you can toggle it at about 4 MHz, maximum.
If you control a GPIO pin from the PRU, you can toggle it at about 200 MHz maximum.
In each case, maximum is a simple program that just says HI, LOW, HI LOW, HI, LOW, etc.
Any additional program, will slow it down, some.
— Graham
