how do qt-embedded build in Angstrom linux images
Hi.
At first, let me describle what I want to do. I want to run qt application on beagle board, so I want to build qt-embedded into angstrom distro.
my question is :
  1. how to build qt-embedded into angstrom distro, in order to run qt applications?
  2. how to write bb-files to build ?
    please give me some advice ?
thanks in advance!
/favor
Hi.
my question is :
if you're running angstrom, qt-embedded 4.4.3 is already prebuilt in the feeds. If you want to build it yourself using OE, you only need to do 'bitbake qt-embedded'
Put this in your recipe:
DEPENDS = "qt-embedded"
inherit qtopia4core
That should pretty much handle everything.
regards,
Koen
