Hi, I am new to Beaglebone, and it seems that analog is not enabled. I am using a new Beaglebone Black Rev C with debian linux version 4.4. I tried both the default image and the image on the board, and neither had the analog enabled.
My approach was wrong because you need the devicetree, so follow William’s docs.
John
Not necessarily wrong. The ADC device tree file would, and will infact load the same device module. The only problem with just loading the kernel module, is the pins will be in whatever the default state is after boot up. Which I’m not certain what state that would be . . .
