How can I enable the pruss uio driver for the 4.4 TI kernels (RT to be exact)?
It looks like the pru_rproc driver is always loaded at boot time and blocks the uio from working correctly. I have tried to enable/disable the cape_overlays in the uEnv.txt without success.
I’m using the IoT Stretch Snapshot image right now, as this the only one where the PRU driver does not make problems during boot.
What I have tried so far:
- Blacklisting pru_rproc - did not work, pru_rproc still loads
- enabling/disabling the uEnv.txt settings
- loading uio_pruss manually via modprobe
- loading the uio_pruss_enable overlay manually
dmesg does not show anything suspicious. I checked for anything to show up in /sys/class/uio and /dev/uio*
Any ideas what could be the problem?
first make sure u-boot overlays are enabled, run:
With v4.4.x-ti allow u-boot overlays to enable/disable these:
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#U-Boot_PRU_Options
ti's v4.4.x-remote_proc pru select:
uboot_overlay_pru=/lib/firmware/AM335X-PRU-RPROC-4-4-TI-00A0.dtbo
for classicuio_pruss:
uboot_overlay_pru=/lib/firmware/AM335X-PRU-UIO-00A0.dtbo
Does not help, even if I enable pru overlay in the the uEnv.txt nothing shows up.
git:/opt/scripts/:[2ce750d881941c5189db9e189af90517e11c079f]
eeprom:[A335BNLT00C02814BBBK6438]
dogtag:[BeagleBoard.org Debian Image 2017-08-21]
bootloader:[microSD-(push-button)]:[/dev/mmcblk0]:[U-Boot 2017.09-rc2-00002-g84a7f2]
bootloader:[eMMC-(default)]:[/dev/mmcblk1]:[U-Boot 2015.01-00001-gb2412df]
kernel:[4.4.84-ti-rt-r120]
nodejs:[v6.11.2]
uboot_overlay_options:[uboot_overlay_pru=/lib/firmware/AM335X-PRU-UIO-00A0.dtbo]
uboot_overlay_options:[enable_uboot_cape_universal=0]
pkg:[bb-cape-overlays]:[4.4.20170728.0-0rcnee1~stretch+20170728]
pkg:[bb-wl18xx-firmware]:[1.20170821-0rcnee1~stretch+20170821]
pkg:[firmware-ti-connectivity]:[20161130-3]
machinekit@beaglebone:~$ sudo dmesg | grep pru
[ 4.687027] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 4.688454] irq: no irq domain found for /ocp/pruss@4a300000/intc@4a320000 !
[ 4.718049] irq: no irq domain found for /ocp/pruss@4a300000/intc@4a320000 !
machinekit@beaglebone:~$ lsmod
Module Size Used by
uio_pruss 4629 0
snd_soc_hdmi_codec 7016 1
pvrsrvkm 442075 0
snd_soc_simple_card 10188 0
omap_sham 27604 0
omap_aes_driver 24545 0
snd_soc_davinci_mcasp 21016 2
snd_soc_edma 1482 1 snd_soc_davinci_mcasp
snd_soc_omap 4317 1 snd_soc_davinci_mcasp
omap_rng 5800 0
snd_soc_core 193427 5 snd_soc_hdmi_codec,snd_soc_davinci_mcasp,snd_soc_edma,snd_soc_omap,snd_soc_simple_card
rng_core 9073 1 omap_rng
tilcdc 33205 0
snd_pcm_dmaengine 6022 2 snd_soc_core,snd_soc_omap
snd_pcm 104606 5 snd_soc_hdmi_codec,snd_soc_davinci_mcasp,snd_soc_core,snd_soc_omap,snd_pcm_dmaengine
snd_timer 24319 1 snd_pcm
snd 74611 3 snd_soc_core,snd_timer,snd_pcm
soundcore 8644 1 snd
evdev 13972 1
tda998x 16533 0
uio_pdrv_genirq 4301 0
uio 11073 2 uio_pruss,uio_pdrv_genirq
usb_f_mass_storage 50607 2
8021q 24326 0
garp 7715 1 8021q
mrp 9531 1 8021q
stp 2533 1 garp
usb_f_acm 8601 2
llc 6405 2 stp,garp
u_serial 13567 3 usb_f_acm
usb_f_ecm 11598 2
usb_f_rndis 26699 2
u_ether 14779 2 usb_f_ecm,usb_f_rndis
libcomposite 54797 16 usb_f_acm,usb_f_ecm,usb_f_rndis,usb_f_mass_storage
iptable_nat 2336 0
nf_conntrack_ipv4 18312 1
nf_defrag_ipv4 1997 1 nf_conntrack_ipv4
nf_nat_ipv4 6966 1 iptable_nat
nf_nat 18982 1 nf_nat_ipv4
nf_conntrack 138629 3 nf_nat,nf_nat_ipv4,nf_conntrack_ipv4
iptable_mangle 2060 0
iptable_filter 2061 0
spidev 9251 0
tieqep 10422 0
pwm_tiehrpwm 6241 0
ip_tables 16062 3 iptable_filter,iptable_mangle,iptable_nat
x_tables 21051 3 ip_tables,iptable_filter,iptable_mangle
pruss_intc 9031 0
pruss 12557 0
So, your eMMC's bootloader is getting in the way, hence your not
booting what you expect:
so kill the MLO file via:
sudo dd if=/dev/zero of=/dev/mmcblk1 count=1 seek=1 bs=128k
Thanks, that looks very promising.
Good, loading the correct PRU driver works now.
However, now I face another problem: When I try to load a device tree overlay from the command line:
echo cape-unversalh > /sys/devices/platform/bone_capemgr/slots
my terminal gets stuck. Running dmesg from another terminal I get:
[ 275.976817] bone_capemgr bone_capemgr: part_number ‘cape-unversalh’, version ‘N/A’
[ 275.976866] bone_capemgr bone_capemgr: slot #4: override
[ 275.976885] bone_capemgr bone_capemgr: slot #4: auto loading handled by U-Boot
Cat reveals:
machinekit@beaglebone:~$ cat /sys/devices/platform/bone_capemgr/slots
0: ------ -1
1: ------ -1
2: ------ -1
3: —l-- -1
4: --O— -1
I get the same result when disabling uboot overlays in the uEnv.txt
cape-universal is also enabled by default with u-boot overlays..
To switch between the 3 different cape-universal overlays, utilize
these 4 variables:
To Disable eMMC:
disable_uboot_overlay_emmc=1
To Disable HDMI VIDEO & AUDIO:
disable_uboot_overlay_video=1
To Disable HDMI AUDIO:
disable_uboot_overlay_audio=1
To Disable WL1835:
disable_uboot_overlay_wireless=1
ps, if you plug in a usb-serial adapter, you'll see exactly what
u-boot is loading.
I have had the same problem, but cannot use the solution (wiping the eMMC's
bootloader) because we use that for other purposes. What did you mean by
the eMMC uboot getting in the way?
