How much current can be sourced from BeagleBoneBlack 3.3V pin
We are building a cape that may need more than 2 Amps current. How much current can be sourced from BeagleBoneBlack 3.3V pins?
Thanks!
http://www.farnell.com/datasheets/1701090.pdf
Page 43. The SRM will be your best friend if you're building a cape.
Yep. You would be surprised what is in the latest SRM. The link above is WAY out of date.
http://elinux.org/Beagleboard:BeagleBoneBlack
