it’s at step 2. After more than 12h it filled up all the available space on my machine (about 4 GB) and of course it stopped…
Because I’m only at step 2 of the first step of the whole procedure, how much space I need to complete it?
Hi
I am also getting that same error, I can see that the recipe for x11-image no longer exists.
It’s quite frustrating…because all the info you see on the net for x11 and Angstrom is “bitbake x11-image”
I was just wondering, did you find out what replaced the x11-image?
Will be grateful if someone could shed some light and excuse me if this has already been answered somewhere
I have been searching the entire afternoon and cant find anything
Thanks for the reply. I am actually building a systemd-gnome-image at the moment. It just gets a bit frustrating if your a noobie and all you want to do is build a image with a lightweight desktop installed and it doesnt help that somewhere along the way you heard about x11 and then limit all your searches to x11
So in desperation I started the gnome build…but feel more at ease now after seeing you post the same instructions i used
The best thing to do when you see out of date information that doesn't work any more is to contact the author of the article. Then they can either set it right or put an update to the article linking to a more recent piece of documentation.
If it is a forum thread or news post then you can reply yourself with a quick note stating that this is no longer applicable.
Just ignoring it and leaving it for others to fall into the same hole is counter productive.
Thanks, yes that’s good advice! I hate it when I read a thread and there is no resolution at the end, but I guess I cant get mad at others if I do the same. So in future I will definately update. I hope that this post helps someone!
