I2c_2 does not show up sys/device/platform/omap . So to enable it Iam trying to patch the following file
Patch:
diff --git a/arch/arm/mach-omap2/board-omap3beagle.c b/arch/arm/mach-omap2/board-omap3beagle.c index 4a71cb7…2148f35 100644 — a/arch/arm/mach-omap2/board-omap3beagle.c +++ b/arch/arm/mach-omap2/board-omap3beagle.c @@ -385,6 +385,7 @@ static int __init omap3_beagle_i2c_init(void) beagle_twldata.vpll2->constraints.name = “VDVI”; omap3_pmic_init(“twl4030”, &beagle_twldata); + omap_register_i2c_bus(2, 400, NULL, 0); /* Bus 3 is attached to the DVI port where devices like the pico DLP * projector don’t work reliably with 400kHz */ omap_register_i2c_bus(3, 100, beagle_i2c_eeprom, ARRAY_SIZE(beagle_i2c_eeprom));
But after applying the command patch -p1 < path in the terminal but it does not execute and show any changes.
