–target=arm-linux-gnueabi
–with-alsa-prefix=/home/u64rj/ti-processor-sdk-linux-am335x-evm-01.00.00.03/linux-devkit/alsa-lib/lib
–with-alsa-inc-prefix=/home/u64rj/ti-processor-sdk-linux-am335x-evm-01.00.00.03/linux-devkit/alsa-lib/include/alsa
loading cache ./config.cache
checking for gcc… arm-linux-gnueabihf-gcc
checking whether the C compiler (arm-linux-gnueabihf-gcc ) works… yes
checking whether the C compiler (arm-linux-gnueabihf-gcc ) is a cross-compiler… yes
checking whether we are using GNU C… yes
checking whether arm-linux-gnueabihf-gcc accepts -g… yes
checking for ranlib… ranlib
checking for a BSD compatible install… /usr/bin/install -c
checking whether ln -s works… yes
checking how to run the C preprocessor… arm-linux-gnueabihf-gcc -E
checking for ANSI C header files… yes
checking for linux/sound.h… yes
checking for working const… yes
checking for inline… inline
checking whether byte ordering is bigendian… no
checking whether time.h and sys/time.h may both be included… yes
checking whether arm-linux-gnueabihf-gcc needs -traditional… no
checking for alsa-driver package… not supported
Fatal error: Cross-compiling isn’t supported…
It has the fatal error. Could you help on spotting what is the problem on the library building on my Sitara SK board (similar to Beaglebone Black)?
checking for gcc... arm-linux-gnueabihf-gcc
checking whether the C compiler (arm-linux-gnueabihf-gcc ) works... yes
cross-compiler... yes
checking whether we are using GNU C... yes
checking whether arm-linux-gnueabihf-gcc accepts -g... yes
checking for ranlib... ranlib
checking for a BSD compatible install... /usr/bin/install -c
checking whether ln -s works... yes
checking how to run the C preprocessor... arm-linux-gnueabihf-gcc -E
checking for ANSI C header files... yes
checking for linux/sound.h... yes
checking for working const... yes
checking for inline... inline
checking whether byte ordering is bigendian... no
checking whether time.h and sys/time.h may both be included... yes
checking whether arm-linux-gnueabihf-gcc needs -traditional... no
checking for alsa-driver package... not supported
Fatal error: Cross-compiling isn't supported...
