How would one change colors in a directory listing? For example, directory entries are currently blue, would like to change to something easier to see.
4andy2001@gmail.com wrote:
[-- multipart/alternative, encoding 7bit, 40 lines --]
[-- text/plain, encoding 7bit, charset: UTF-8, 14 lines --]
Try 'man ls', down at the bottom it says:-
With --color=auto, ls emits color codes only when standard output is
connected to a terminal. The LS_COLORS environment variable can
change the settings. Use the dircolors command to set it.
So you need dircolors......
