Stop the boot process using a serial console and printenv the environment. You need to look for omapfb.mode and omapdss.def_disp in the bootargs (mmcargs). I think that currently the only supported display modes are dvi and tv out. By default, I think that omapfb.mode=dvi:640x480MR-16@60 and omapdss.def_disp=dvi. I haven’t tried it, but you can probably change the resolution and frame rate of the DVI using these bootargs. E.g. try setting omapfb.mode=dvi:1024x768R-16@60 and see what you get. It might work if these are parsed out.
Expect an lcd mode to be added soon to support the Beagleboard Toys 7” LCD panel.
I'm not sure if that's necessary.
From his output I can see:
" ** Unable to read "uEnv.txt" from mmc 0:1 ** "
So its a newer version looking for uEnv.txt instead of boot.scr.
Yes you can create that file yourself. Please also check which display
modes are actually available for your setup.
I suggest doing this step-by-step.
1. Stop the boot process during the countdown.
2. use printenv to see your current parameter values.
3. Use setenv <param-name> <param-value>. Notice the lack of "=".
4. Type boot to boot and test if it works.
Once you get it to work:
Add a line to uEnv.txt (create if necessary) with <param-name> <param-
In uEnv.txt I think thay you can use an "=". So you can copy the
output of the default printenv (default Uboot environment) into
uEnv.txt, put that into the 'boot' partition of the microSD card, and
you get a set of environment vars that you can configure by modifying
the text file.
