how to change dvi resolution and use a camera
I have installed, on a beagleboard rev c2, the new image of the kernel 2.6.32 at http://www.angstrom-distribution.org/demo/beagleboard/ and I have a monitor resolution of 640x480.
I tried to change the resolution by setting the environment variable dvimode (setenv dvimode ‘1024x768MR-24@60’) and also by adding to the bootargs variable the string: ‘omapfb.video_mode=1024x768MR-24@60’, but nothing has happened.
Have I to install an additional package to be able to change the monitor resolution? Which one?
I have also tried to change the resolution by the GUI in System->Preferences->Monitors, but I can see only the 640X480 option …
I’m also trying to use a camera, but I met some difficulties. Now I’m installing a kernel module from UVC
http://www.ideasonboard.org/uvc/ . Have you some advice?
Thanks in advance.
Luciana
Hi…
you can enter in this address:
http://elinux.org/BeagleBoardFAQ#.22DSS2.22_display_driver_prior_to_2.6.29
only you need reset the beagleborad, enter to omap prompt and writ this comand´s
OMAP3 beagleboard.org # setenv bootargs ‘console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw rootwait omapfb.video_mode=1024x768MR-24@59’
OMAP3 beagleboard.org. # saveenv
OMAP3 beagleboard.org # reset
Greetings
2011/1/21 Luciana Carota <luciana.carota@gmail.com>
Doing saveenv is probably the works thing you can do on a beagle. Leave the default env intact and use a boot.scr
thanks for your reply. I tried by:
but the resolution is 640x480… Is that due to the demo image ?
Greetings
Luciana
Can you elaborate? I do this all the time, and I’d like to know more about why its a problem. Especially since all we’re doing is essentially eriing to nand, nothing weird. Thanks in advance for any clarification.
Yes I can
2011/1/21 Koen Kooi <koen@beagleboard.org>
