I’m re-posting this question (that was part of another issue that got no responses). 'am hoping someone from the bbb s/w team can chime in.
I wish to change the 192.168.7.x scheme to say the 192.168.8.x scheme. I’m running So, I tried changing the ip info in the file:
/etc/network/interfaces
to now say:
iface usb0 inet static
address 192.168.8.2
netmask 255.255.255.0
network 192.168.8.0
gateway 192.168.8.1
broadcast 192.168.8.3
After a reboot, it did not use this new info, bur somehow reverted back to the old info (checked via ifconfig for usb0). There was an error at the end of the reboot cycle, that is unclear if related:
[ 10.216600] systemd-udevd[83]: worker [101] terminated by signal 11 (Segmentation fault)
[ 10.230355] systemd-udevd[83]: worker [101] failed while handling ‘/devices/ocp.2/47400000.usb/musb-hdrc.0.auto/gadget/net/usb0’
'am wondering if:
. if I’m not following the proper steps to update/persist, or
. the original 192.168.7.x info is hard-coded somewhere, or
. is there an usb-driver (for usb0) issue with the
05/03/13 3.8.11 Angstrom image that I’m using.
Any help from the linux gurus is appreciated.
thanks,
/venkat
