How to compile a C program for beagle board in Windows or Linux?
Is there a step by step tutorial on this? I tried CodeSourery G++ IDE
30-day eval but when I compiled and ran in beagle I got some errors.
Maybe it's the IDE project settings... (Cortex A8, little-endian, ARM
simulator, host...)
At the beginning I ran into the same problems... it was unclear to me
how to get a program to cross compile and run successfully on the
Angstrom distribution. I followed the instructions on this site:
Note that GPP, "general purpose processor", is the ARM core, i.e. what
you need. Those instructions if followed closely will build a cross-
compiler for your C code, situated in something like .../cross/armv7a/
bin .
You have to have a complete Open Embedded installation from http://elinux.org/BeagleBoardAndOpenEmbeddedGit to build your own
cross compiler and it seems you can't cross compile on Windows.
simulator, host...)
If it is a simple program (and you are using Angstrom), try installing
task-native-sdk. I use this to build small programs on the Beagle
itself.
