How to configure the Telnet Daemon for Angstrom
I tried 'opkg install telnetd', but it just gives an error. Has got
the telnetd running?
Bill
you want 'netkit-telnet' for telnet stuff, but why not use ssh? The dropbear ssh daemon is installed by default.
regards,
Koen
Thanks Koen. Good point on ssh. But when I try to use an ssh client
(Putty on port#22) it times out. I see that Dropbear is running and
from the config file it is listening on port 22. Is there some sort of
firewall that is causing Angstrom to block the port? From the
beagleboard, I can access the network with no problem.
Bill
Btw, Looks to be a windows issue ... I can ssh from a linux box with no issues.
Bill
