Dear all,
I’m running a 4DCAPE-70T on my BeagleBone Black with Debian Linux (as recommended from 4D Systems based on the following package: http://rcn-ee.net/deb/testing/2014-02-18/).
It’s all fine in general, but I have some questions which 4D Systems won’t answer to me (as argumented that those are SW-questions and no HW-support):
I found out, that I can turn on / off the Backlight of the Display by i.a. using
echo 1 > /sys/class/backlight/backlight.11/bl_power
Is there a real “Display off” mode, which can be controlled by software (Bonescript / javascript or Shell)?
How can I prevent the display to “sleep”? It always goes into some kind of sleep modus, if there is no interaction with the display. So, it “sleeps”, when my script turns the backlight on and hence you have e.g. to touch it. In my concrete scenario, I would like to stop this sleep mode.
Is there any chance to use e.g. the “Power”-Button for a concrete Script? I do not need this button, but it would be great, if it could call a script which turns on the Display (or it’s backlight).
Is there any chance to control the LEDs by Software? I do not need e.g. a Power LED, but I would like to have an “alert LED”, which is controlled by my software.
Kind regards,
Stefan
