We are using BeagleBoneBlack based custom Linux board.
It has 256MB of RAM and 4GB of eMMC.
Currently RFS size of the project is 163MB. While RFS partition size is 500MB.
For testing, we added 20 number of big files(10MB size) and started firmware upgrade process.
During the firmware Upgrade process we see following error when roofs is being written,
We could solve it by changing
/proc/sys/vm/min_free_kbytes
from 2005 to 4096.
But now my doubt is what should be the ideal value for that, what factors we should consider while calculating it. From the kernel documentation I don’t get that information,
but I could understand one thing that is this value can not be too low or too high or else system will break.
Any suggestion/pointer ?
[ 6676.674219] mmcqd/1: page allocation failure: order:1, mode:0x200020 [ 6676.674256] CPU: 0 PID: 612 Comm: mmcqd/1 Tainted: P O 3.12.10-005-ts-armv7l #2 [ 6676.674321] [<c0012d24>] (unwind_backtrace+0x0/0xf4) from [<c0011130>] (show_stack+0x10/0x14) [ 6676.674355] [<c0011130>] (show_stack+0x10/0x14) from [<c0087548>] (warn_alloc_failed+0xe0/0x118) [ 6676.674383] [<c0087548>] (warn_alloc_failed+0xe0/0x118) from [<c008a3ac>] (__alloc_pages_nodemask+0x74c/0x8f8) [ 6676.674413] [<c008a3ac>] (__alloc_pages_nodemask+0x74c/0x8f8) from [<c00b2e8c>] (cache_alloc_refill+0x328/0x620) [ 6676.674436] [<c00b2e8c>] (cache_alloc_refill+0x328/0x620) from [<c00b3224>] (__kmalloc+0xa0/0xe8) [ 6676.674471] [<c00b3224>] (__kmalloc+0xa0/0xe8) from [<c0212904>] (edma_prep_slave_sg+0x84/0x388) [ 6676.674505] [<c0212904>] (edma_prep_slave_sg+0x84/0x388) from [<c02ec0a0>] (omap_hsmmc_request+0x414/0x508) [ 6676.674544] [<c02ec0a0>] (omap_hsmmc_request+0x414/0x508) from [<c02d6748>] (mmc_start_request+0xc4/0xe0) [ 6676.674568] [<c02d6748>] (mmc_start_request+0xc4/0xe0) from [<c02d7530>] (mmc_start_req+0x2d8/0x38c) [ 6676.674589] [<c02d7530>] (mmc_start_req+0x2d8/0x38c) from [<c02e4818>] (mmc_blk_issue_rw_rq+0xb4/0x9d8) [ 6676.674611] [<c02e4818>] (mmc_blk_issue_rw_rq+0xb4/0x9d8) from [<c02e52e0>] (mmc_blk_issue_rq+0x1a4/0x468) [ 6676.674631] [<c02e52e0>] (mmc_blk_issue_rq+0x1a4/0x468) from [<c02e5c68>] (mmc_queue_thread+0x88/0x118) [ 6676.674657] [<c02e5c68>] (mmc_queue_thread+0x88/0x118) from [<c004d8b8>] (kthread+0xb4/0xb8) [ 6676.674681] [<c004d8b8>] (kthread+0xb4/0xb8) from [<c000e298>] (ret_from_fork+0x14/0x3c) [ 6676.674691] Mem-info: [ 6676.674700] Normal per-cpu: [ 6676.674711] CPU 0: hi: 90, btch: 15 usd: 79 [ 6676.674739] active_anon:4889 inactive_anon:13 isolated_anon:0 [ 6676.674739] active_file:8082 inactive_file:43196 isolated_file:0 [ 6676.674739] unevictable:422 dirty:2 writeback:1152 unstable:0 [ 6676.674739] free:3286 slab_reclaimable:1090 slab_unreclaimable:915 [ 6676.674739] mapped:1593 shmem:39 pagetables:181 bounce:0 [ 6676.674739] free_cma:1982 [ 6676.674800] Normal free:13144kB min:2004kB low:2504kB high:3004kB active_anon:19556kB inactive_anon:52kB active_file:32328kB inactive_file:172784kB unevictable:o [ 6676.674813] lowmem_reserve[]: 0 0 0 [ 6676.674831] Normal: 2584*4kB (UMC) 217*8kB (C) 57*16kB (C) 5*32kB (C) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB 0*8192kB = 13144kB [ 6676.674885] 51661 total pagecache pages [ 6676.674900] 0 pages in swap cache [ 6676.674910] Swap cache stats: add 0, delete 0, find 0/0 [ 6676.674918] Free swap = 0kB [ 6676.674925] Total swap = 0kB [ 6676.674938] SLAB: Unable to allocate memory on node 0 (gfp=0x20) [ 6676.674949] cache: kmalloc-8192, object size: 8192, order: 1 [ 6676.674962] node 0: slabs: 3/3, objs: 3/3, free: 0 [ 6676.674984] omap_hsmmc 481d8000.mmc: prep_slave_sg() failed [ 6676.674997] omap_hsmmc 481d8000.mmc: MMC start dma failure [ 6676.676181] mmcblk0: unknown error -1 sending read/write command, card status 0x900 [ 6676.676300] end_request: I/O error, dev mmcblk0, sector 27648 [ 6676.676318] Buffer I/O error on device mmcblk0p9, logical block 896 [ 6676.676329] lost page write due to I/O error on mmcblk0p9 [ 6676.676401] end_request: I/O error, dev mmcblk0, sector 27656 [ 6676.676415] Buffer I/O error on device mmcblk0p9, logical block 897 [ 6676.676425] lost page write due to I/O error on mmcblk0p9 [ 6676.676450] end_request: I/O error, dev mmcblk0, sector 27664 [ 6676.676461] Buffer I/O error on device mmcblk0p9, logical block 898 [ 6676.676471] lost page write due to I/O error on mmcblk0p9 [ 6676.676494] end_request: I/O error, dev mmcblk0, sector 27672 [ 6676.676505] Buffer I/O error on device mmcblk0p9, logical block 899 [ 6676.676515] lost page write due to I/O error on mmcblk0p9 [ 6676.676537] end_request: I/O error, dev mmcblk0, sector 27680 [ 6676.676548] Buffer I/O error on device mmcblk0p9, logical block 900 [ 6676.676558] lost page write due to I/O error on mmcblk0p9 [ 6676.676580] end_request: I/O error, dev mmcblk0, sector 27688 [ 6676.676591] Buffer I/O error on device mmcblk0p9, logical block 901 [ 6676.676601] lost page write due to I/O error on mmcblk0p9 [ 6676.676622] end_request: I/O error, dev mmcblk0, sector 27696 [ 6676.676634] Buffer I/O error on device mmcblk0p9, logical block 902 [ 6676.676643] lost page write due to I/O error on mmcblk0p9 [ 6676.676665] end_request: I/O error, dev mmcblk0, sector 27704 [ 6676.676676] Buffer I/O error on device mmcblk0p9, logical block 903 [ 6676.676685] lost page write due to I/O error on mmcblk0p9 [ 6676.676707] end_request: I/O error, dev mmcblk0, sector 27712 [ 6676.676718] Buffer I/O error on device mmcblk0p9, logical block 904 [ 6676.676728] lost page write due to I/O error on mmcblk0p9 [ 6676.676749] end_request: I/O error, dev mmcblk0, sector 27720 [ 6676.678266] mmcqd/1: page allocation failure: order:1, mode:0x200020 [ 6676.678285] CPU: 0 PID: 612 Comm: mmcqd/1 Tainted: P O 3.12.10-005-ts-armv7l #2 [ 6676.678330] [<c0012d24>] (unwind_backtrace+0x0/0xf4) from [<c0011130>] (show_stack+0x10/0x14) [ 6676.678358] [<c0011130>] (show_stack+0x10/0x14) from [<c0087548>] (warn_alloc_failed+0xe0/0x118) [ 6676.678385] [<c0087548>] (warn_alloc_failed+0xe0/0x118) from [<c008a3ac>] (__alloc_pages_nodemask+0x74c/0x8f8) [ 6676.678412] [<c008a3ac>] (__alloc_pages_nodemask+0x74c/0x8f8) from [<c00b2e8c>] (cache_alloc_refill+0x328/0x620) [ 6676.678434] [<c00b2e8c>] (cache_alloc_refill+0x328/0x620) from [<c00b3224>] (__kmalloc+0xa0/0xe8) [ 6676.678464] [<c00b3224>] (__kmalloc+0xa0/0xe8) from [<c0212904>] (edma_prep_slave_sg+0x84/0x388) [ 6676.678493] [<c0212904>] (edma_prep_slave_sg+0x84/0x388) from [<c02ec0a0>] (omap_hsmmc_request+0x414/0x508) [ 6676.678524] [<c02ec0a0>] (omap_hsmmc_request+0x414/0x508) from [<c02d6748>] (mmc_start_request+0xc4/0xe0) [ 6676.678547] [<c02d6748>] (mmc_start_request+0xc4/0xe0) from [<c02d7530>] (mmc_start_req+0x2d8/0x38c) [ 6676.678568] [<c02d7530>] (mmc_start_req+0x2d8/0x38c) from [<c02e4994>] (mmc_blk_issue_rw_rq+0x230/0x9d8) [ 6676.678589] [<c02e4994>] (mmc_blk_issue_rw_rq+0x230/0x9d8) from [<c02e52e0>] (mmc_blk_issue_rq+0x1a4/0x468) [ 6676.678608] [<c02e52e0>] (mmc_blk_issue_rq+0x1a4/0x468) from [<c02e5c68>] (mmc_queue_thread+0x88/0x118) [ 6676.678632] [<c02e5c68>] (mmc_queue_thread+0x88/0x118) from [<c004d8b8>] (kthread+0xb4/0xb8) [ 6676.678655] [<c004d8b8>] (kthread+0xb4/0xb8) from [<c000e298>] (ret_from_fork+0x14/0x3c) [ 6676.678664] Mem-info: [ 6676.678672] Normal per-cpu: [ 6676.678683] CPU 0: hi: 90, btch: 15 usd: 84 [ 6676.678709] active_anon:4889 inactive_anon:13 isolated_anon:0 [ 6676.678709] active_file:8082 inactive_file:43196 isolated_file:0 [ 6676.678709] unevictable:422 dirty:2 writeback:896 unstable:0 [ 6676.678709] free:3286 slab_reclaimable:1090 slab_unreclaimable:910 [ 6676.678709] mapped:1593 shmem:39 pagetables:181 bounce:0 [ 6676.678709] free_cma:1982 [ 6676.678764] Normal free:13144kB min:2004kB low:2504kB high:3004kB active_anon:19556kB inactive_anon:52kB active_file:32328kB inactive_file:172784kB unevictable:o [ 6676.678776] lowmem_reserve[]: 0 0 0 [ 6676.678791] Normal: 2584*4kB (UMC) 217*8kB (C) 57*16kB (C) 5*32kB (C) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB 0*8192kB = 13144kB [ 6676.678842] 51661 total pagecache pages [ 6676.678854] 0 pages in swap cache [ 6676.678864] Swap cache stats: add 0, delete 0, find 0/0 [ 6676.678871] Free swap = 0kB [ 6676.678878] Total swap = 0kB [ 6676.678898] omap_hsmmc 481d8000.mmc: prep_slave_sg() failed [ 6676.678911] omap_hsmmc 481d8000.mmc: MMC start dma failure [ 6676.679631] mmcblk0: unknown error -1 sending read/write command, card status 0x900 [ 6676.681433] mmcqd/1: page allocation failure: order:1, mode:0x200020 [ 6676.681455] CPU: 0 PID: 612 Comm: mmcqd/1 Tainted: P O 3.12.10-005-ts-armv7l #2 [ 6676.681494] [<c0012d24>] (unwind_backtrace+0x0/0xf4) from [<c0011130>] (show_stack+0x10/0x14) [ 6676.681523] [<c0011130>] (show_stack+0x10/0x14) from [<c0087548>] (warn_alloc_failed+0xe0/0x118) [ 6676.681546] [<c0087548>] (warn_alloc_failed+0xe0/0x118) from [<c008a3ac>] (__alloc_pages_nodemask+0x74c/0x8f8) [ 6676.681570] [<c008a3ac>] (__alloc_pages_nodemask+0x74c/0x8f8) from [<c00b2e8c>] (cache_alloc_refill+0x328/0x620) [ 6676.681592] [<c00b2e8c>] (cache_alloc_refill+0x328/0x620) from [<c00b3224>] (__kmalloc+0xa0/0xe8) [ 6676.681618] [<c00b3224>] (__kmalloc+0xa0/0xe8) from [<c0212904>] (edma_prep_slave_sg+0x84/0x388) [ 6676.681644] [<c0212904>] (edma_prep_slave_sg+0x84/0x388) from [<c02ec0a0>] (omap_hsmmc_request+0x414/0x508) [ 6676.681673] [<c02ec0a0>] (omap_hsmmc_request+0x414/0x508) from [<c02d6748>] (mmc_start_request+0xc4/0xe0) [ 6676.681695] [<c02d6748>] (mmc_start_request+0xc4/0xe0) from [<c02d7530>] (mmc_start_req+0x2d8/0x38c) [ 6676.681715] [<c02d7530>] (mmc_start_req+0x2d8/0x38c) from [<c02e4994>] (mmc_blk_issue_rw_rq+0x230/0x9d8) [ 6676.681735] [<c02e4994>] (mmc_blk_issue_rw_rq+0x230/0x9d8) from [<c02e52e0>] (mmc_blk_issue_rq+0x1a4/0x468) [ 6676.681755] [<c02e52e0>] (mmc_blk_issue_rq+0x1a4/0x468) from [<c02e5c68>] (mmc_queue_thread+0x88/0x118) [ 6676.681778] [<c02e5c68>] (mmc_queue_thread+0x88/0x118) from [<c004d8b8>] (kthread+0xb4/0xb8) [ 6676.681800] [<c004d8b8>] (kthread+0xb4/0xb8) from [<c000e298>] (ret_from_fork+0x14/0x3c) [ 6676.681809] Mem-info: [ 6676.681816] Normal per-cpu: [ 6676.681826] CPU 0: hi: 90, btch: 15 usd: 88 [ 6676.681852] active_anon:4889 inactive_anon:13 isolated_anon:0 [ 6676.681852] active_file:8082 inactive_file:43196 isolated_file:0 [ 6676.681852] unevictable:422 dirty:2 writeback:768 unstable:0 [ 6676.681852] free:3286 slab_reclaimable:1090 slab_unreclaimable:906 [ 6676.681852] mapped:1593 shmem:39 pagetables:181 bounce:0 [ 6676.681852] free_cma:1982 [ 6676.681908] Normal free:13144kB min:2004kB low:2504kB high:3004kB active_anon:19556kB inactive_anon:52kB active_file:32328kB inactive_file:172784kB unevictable:o 2016-07-19T06:47:28.562553-04:00 kernel: [ 6676.681920] lowmem_reserve[]: 0 0 0
