I did finish the kernel-module example but after running the command insmod hellokernel.ko, I have to type the command dmesg | tail to see the result.
I hope someone experienced about this issue can help me.
Thank you for your time.
Best regards,
Thang Nguyen
I guess I forgot to question in my last post. I will ask again.
Is there any way to make the kernel module print directly on the text command line without using the display kernel message command [dmesg | tail]? Cause in my example, after load the kernel hellokernel, I have to type the display kernel messge to see the result of my print command. I ask this question cause when my friend ran my module it apprear directly on his text command line, but t didn’t on my text command line. Should I do anything to make it works the same way?
This is my hellokernel.c
#include <linux/init.h>
#include <linux/module.h>
MODULE_LICENSE(“Dual BSD/GPL”);
static int hello_init(void)
printk(KERN_ALERT “Hello, world\n”);
return 0;
static void hello_exit(void)
printk(KERN_ALERT “Goodbye, cruel world\n”);
module_init(hello_init);
module_exit(hello_exit);
Best regards,
Thang Nguyen
on his text command line, but t didn't on my text command line. Should I
MODULE_LICENSE("Dual BSD/GPL");
printk(KERN_ALERT "Hello, world\n");
return 0;
printk(KERN_ALERT "Goodbye, cruel world\n");
either:
http://mail.nl.linux.org/kernelnewbies/2004-07/msg00020.html
or just remove the KERN_ALERT.
Vladimir
Hi Valdimir. Thank you so much ^_^. I tried to search on Google but I did use the wrong key word then.
