I have managed to download u-boot-main.
I located the file beagle.h found at 'u-boot-main/board/omap3/beagle/
beagle.h'.
My aim is to get the UART header pins configured on the mux. So I did
following;
I edited the lines of code with the heading Bluetooth in '../
beagle.h'.
My new file now has the following lines:
MUX_VAL(CP(MMC2_DAT6), (IEN | PTU | EN | M4)) /*GPIO_138*/\
MUX_VAL(CP(MMC2_DAT7), (IEN | PTU | EN | M4)) /*GPIO_139*/\
/*Bluetooth*/\
MUX_VAL(CP(MCBSP3_DX), (IEN | PTU | EN | M1)) /*UART2_CTS*/\
MUX_VAL(CP(MCBSP3_DR), (IDIS | PTD | DIS | M1)) /*UART2_TX*/\
MUX_VAL(CP(MCBSP3_CLKX), (IDIS | PTD | DIS | M1)) /*UART2_RTS*/\
MUX_VAL(CP(MCBSP3_FSX), (IEN | PTD | DIS | M1)) /*UART2_RX*/\
MUX_VAL(CP(UART2_CTS), (IDIS | PTD | DIS | M4)) /*GPIO_144*/\
MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M4)) /*GPIO_145*/\
MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M4)) /*GPIO_146*/\
MUX_VAL(CP(UART2_RX), (IDIS | PTD | DIS | M4)) /*GPIO_147*/\
/*Modem Interface */\
MUX_VAL(CP(UART1_TX), (IDIS | PTD | DIS | M0)) /*UART1_TX*/\
MUX_VAL(CP(UART1_RTS), (IDIS | PTD | DIS | M4)) /*GPIO_149*/ \
I then rebuilt u-boot-main to give me u-boot.bin.
I achieved this by using the following commands:
#make CROSS_COMPILE=arm-none-linux-gnueabi- mrproper
#make CROSS_COMPILE=arm-none-linux-gnueabi- omap3_beagle_config
would you say this is correct to enable UART2 on the header expansion
pins?
I have tested with some C code to see if I can send and recieve data
on the UART but with no luck. I am unsure if there is a problem with
my C code or that u-boot.bin isn't working properly.
Is there a method to test that the UART2 pins are setup correctly with
the mux?
Does anyone have a u-boot.bin file they can share that has the UART2
setup so I can just load it onto my SD card boot partition?
Thank you for your time,
Any assistance is greatly appreciated.
Rob
