hi
The BBB has a kernel 4.4 and has a overlay ‘universaln’ loaded by default. I can see there is ttyO[0-4] unuder /dev/. Then I did 'sudo config-pin P9.13 uart && sudo config-pin P9.11 uart ’ and the uart function works well.
I wonder how do I enable the RS485 ? I only see there is a overlay ‘BB-UART4-RS485’ but when I tried to load it, it said ‘file exist’. I read at the source dtbo and there is a pin P9.27, what is that?
I want to connect to a device which has rx, tx and gnd, using MODBUS (half-duplex).
/Peilang
Hi Peilang
I’ve had some of the same questions, and based on previous postings on this list RS485 isn’t enabled in the regular build - though I understand it is being integrated into the 4.4 release. The issue being the serial port is so overloaded with historical functionality.For RS485 there is a separate
\KERNEL\drivers\tty\serial\omap-serial.c
I rebuilt the kernel using RobertCNelson’s yakbuild (amazing…) to enable the RS485 capability.
The details of what I did are at
https://github.com/neilh10/yakbuild/wiki/BBB-RS485-Tutorial
I’ve got messages flowing out where P9.22 is the DirectionEnable
I am building some hardware, and planning on using a MAX13487EESA+ which auto manages the Tx output driver.
