How to enable UART1 using dtb-rebuilder?
I was able to enable all the UART serial connections on my BBB before I switched to the last kernel.
In the following tutorial it was explained very well, how to change the cape-fuctions accordingly and everything worked fine.
Now I have the latest Ubuntu distro on my board. I ve downloaded the last dtb-rebuilder for 4.1-ti and try to enable again my old uart ports.
It seems that everything is changed since 3.8. I open my am335x-boneblack-dts, but I can find any
#include
directive which helps to activate/deactivate peripherals.
The readme in the repository says nothing about that.
What should I do?
How can I compile my dtb-file for my board?
4.1-ti supports overlays, so you can either do it like "3.8".
https://github.com/beagleboard/bb.org-overlays/blob/master/src/arm/BB-UART1-00A0.dts
or create a custom *.dtb
4.1-ti supports overlays, so you can either do it like “3.8”.
That’s nice,
but I cannot find any guide that helps me to install the new cape like in the first tutorial I posted above.
How do I use such overlays?
Should I copy them somewhere?
Follow steps 1 -> 3:
https://github.com/beagleboard/bb.org-overlays/blob/master/readme.md
Then either:
sudo sh -c "echo 'BB-UART1' > /sys/devices/platform/bone_capemgr/slots"
or:
/boot/uEnv.txt
cape_enable=bone_capemgr.enable_partno=BB-UART1
http://www.embeddedhobbyist.com/2015/09/beaglebone-black-updating-device-tree-files/
Thank both of you.
Your explanations did work very well and I can load capes without a problem.
The only problem is that no capes are loaded at boot startup process. So I need to load the cape everytime.
The following answer didn’t help further. I have that flag as default in my beagle.
The only working way seems to be:
/boot/uEnv.txt // open that file and write the following:
But I thought that this is just an alternative, not the first choice.
Any idea?
