Could you explain me the method to enabling adb support on the BeagleBoneBlack.
I use the rowboat source and 3.8 kernel (with option CONFIG_USB_FUNCTIONFS=y)
I enabling adb on my board :
Settings->Applications->Development and then enable the “USB debugging” option.
I also created an udev rules called /etc/udev/rules.d/51-android.rules on my ubuntu 12.04
/* For Gusty/Hardy, add following lines to file, save & exit */
SUBSYSTEM=="usb", SYSFS{idVendor}=="18d1", MODE="0666"
SUBSYSTEM=="usb", SYSFS{idVendor}=="0451", MODE="0666"
But when i use the command “adb devices” my devices are not detected :
adb devices
List of devices attached
Do you have any suggestions ?
Thanks by advance
Could i have a .config which allow me to have a adb enabling?
When i use the command lsub on my ubuntu laptop, i don’t my BBB.
lsusb
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 04f2:b354 Chicony Electronics Co., Ltd
Please help!
Hello !
I have the same problem but my device appear as
Bus 002 Device 010: ID 1d6b:0105 Linux Foundation FunctionFS Gadget
Are you solve this problem?
Please tell me the steps if solved or try to contact me if not, to reach to optimum solution
Best Regards,
Eng Sultan
