Hi I have downloaded the files from the below source
http://www.angstrom-distribution.org/demo/beagleboard/
1) Partitioned the hard disk (FAT 32, Ext3 formats)
2)Copied MLO,uImage.bin(2.6.29),U-boot bin into FAT 32 file system
3) Untar the Angstrom image into the ext 32 partition
4) unzip the modules file into /lib/modules in ext 32 partition
5) setting environmental variable
Angstrom is loaded,
Mouse and Keyboard are working fine
I have connectes Logitech camera to the USB hub, but its not working /
I am unable to see any video(am I doing any mistale)
BB detected the camera interface.
Please kindle help, I have spent several hours but i didn't succeed
with Camera and USB wifi dongle.
Texas Instruments X-Loader 1.4.2 (Feb 19 2009 - 12:01:24)
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2009.01-dirty (Feb 19 2009 - 12:23:21)
I2C: ready
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
DRAM: 256 MB
NAND: 256 MiB
Using default environment
MUSB: using high speed
In: serial usbtty
Out: serial usbtty
Err: serial usbtty
Board revision C
Serial #5ac400030000000004013f8901001001
reading boot.scr
** Unable to read "boot.scr" from mmc 0:1 **
reading uImage.bin
2863508 bytes read
reading ramdisk.gz
** Unable to read "ramdisk.gz" from mmc 0:1 **
Booting from mmc ...
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Angstrom/2.6.29/beagleboard
Data Size: 2863444 Bytes = 2.7 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
Linux........................................................................................................................................................................................
done, booting the kernel.
[ 0.000000] Linux version 2.6.29-omap1 (koen@dominion) (gcc version
4.3.3 (GCC) ) #1 Mon May 25 17:15:11 CEST 2009
[ 0.000000] CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7),
cr=10c5387f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing
instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430 ES3.0
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xd7000000 size:
0x100000
[ 0.000000] Reserving 14680064 bytes SDRAM for VRAM
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on.
Total pages: 65024
[ 0.000000] Kernel command line: console=ttyS2,115200n8 root=/dev/
mmcblk0p2 rw rootfstype=ext3 rootwait
[ 0.000000] Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96
interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP34xx GPIO hardware version 2.5
[ 0.000000] PID hash table entries: 1024 (order: 10, 4096 bytes)
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5,
131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536
bytes)
[ 0.000000] Memory: 128MB 128MB = 256MB total
[ 0.000000] Memory: 239232KB available (5328K code, 567K data, 204K
init)
[ 0.000000] Calibrating delay loop... 491.57 BogoMIPS (lpj=1921024)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] net_namespace: 1036 bytes
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 21.376373] OMAP DMA hardware revision 4.0
[ 21.414855] bio: create slab <bio-0> at 0
[ 21.472839] OMAP DSS rev 2.0
[ 21.472961] OMAP DISPC rev 3.0
[ 21.472991] OMAP VENC rev 2
[ 21.473144] OMAP DSI rev 1.0
[ 21.475158] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 21.478759] twl4030: PIH (irq 7) chaining IRQs 368..375
[ 21.478790] twl4030: power (irq 373) chaining IRQs 376..383
[ 21.479278] twl4030: gpio (irq 368) chaining IRQs 384..401
[ 21.481750] regulator: VMMC1: 1850 <--> 3150 mV normal standby
[ 21.482543] regulator: VDAC: 1800 mV normal standby
[ 21.483367] regulator: VUSB1V5: 1500 <--> 0 mV normal standby
[ 21.484161] regulator: VUSB1V8: 1800 <--> 0 mV normal standby
[ 21.484985] regulator: VUSB3V1: 3100 <--> 0 mV normal standby
[ 21.485778] regulator: VPLL2: 1800 mV normal standby
[ 21.486602] regulator: VSIM: 1800 <--> 3000 mV normal standby
[ 21.486785] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
[ 21.488677] SCSI subsystem initialized
[ 21.489868] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 21.491241] usbcore: registered new interface driver usbfs
[ 21.491760] usbcore: registered new interface driver hub
[ 21.492126] usbcore: registered new device driver usb
[ 21.494934] Bluetooth: Core ver 2.14
[ 21.495422] NET: Registered protocol family 31
[ 21.495422] Bluetooth: HCI device and connection manager
initialized
[ 21.495452] Bluetooth: HCI socket layer initialized
[ 21.496307] cfg80211: Using static regulatory domain info
[ 21.496307] cfg80211: Regulatory domain: US
[ 21.496337] (start_freq - end_freq @ bandwidth),
(max_antenna_gain, max_eirp)
[ 21.496337] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi,
2700 mBm)
[ 21.496368] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 21.496398] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 21.496398] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 21.496429] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi,
2300 mBm)
[ 21.496459] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi,
3000 mBm)
[ 21.496459] cfg80211: Calling CRDA for country: US
[ 21.499542] musb_hdrc: version 6.0, musb-dma, otg (peripheral
+host), debug=0
[ 21.501495] musb_core_init 1421: reconfigure software for static
FIFOs
[ 21.502227] musb_hdrc musb_hdrc: musb_init_controller failed with
status -19
[ 21.503875] NET: Registered protocol family 2
[ 21.504119] IP route cache hash table entries: 2048 (order: 1, 8192
bytes)
[ 21.504699] TCP established hash table entries: 8192 (order: 4,
65536 bytes)
[ 21.504943] TCP bind hash table entries: 8192 (order: 3, 32768
bytes)
[ 21.505065] TCP: Hash tables configured (established 8192 bind
8192)
[ 21.505096] TCP reno registered
[ 21.505340] NET: Registered protocol family 1
[ 21.509246] VFS: Disk quotas dquot_6.5.2
[ 21.509338] Dquot-cache hash table entries: 1024 (order 0, 4096
bytes)
[ 21.509857] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 21.510528] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red
Hat, Inc.
[ 21.511322] msgmni has been set to 467
[ 21.516448] alg: No test for stdrng (krng)
[ 21.516571] io scheduler noop registered
[ 21.516571] io scheduler anticipatory registered
[ 21.516601] io scheduler deadline registered
[ 21.516784] io scheduler cfq registered (default)
[ 21.537628] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 21.559906] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a
ST16654
[ 21.580505] serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a
ST16654
[ 21.601196] serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a
ST16654
[ 21.601226] console [ttyS2] enabled
[ 22.112579] brd: module loaded
[ 22.121002] loop: module loaded
[ 22.124481] usbcore: registered new interface driver catc
[ 22.130065] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 22.136291] usbcore: registered new interface driver kaweth
[ 22.141967] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB
Ethernet driver
[ 22.150177] usbcore: registered new interface driver pegasus
[ 22.155914] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet
driver
[ 22.163146] usbcore: registered new interface driver rtl8150
[ 22.169128] usbcore: registered new interface driver asix
[ 22.174804] usbcore: registered new interface driver cdc_ether
[ 22.180969] usbcore: registered new interface driver dm9601
[ 22.186889] usbcore: registered new interface driver smsc95xx
[ 22.192962] usbcore: registered new interface driver gl620a
[ 22.198791] usbcore: registered new interface driver net1080
[ 22.204772] usbcore: registered new interface driver plusb
[ 22.210601] usbcore: registered new interface driver rndis_host
[ 22.216857] usbcore: registered new interface driver cdc_subset
[ 22.223144] Broadcom 43xx driver loaded [ Features: L, Firmware-ID:
FW13 ]
[ 22.230468] usbcore: registered new interface driver zd1211rw
[ 22.236511] usbcore: registered new interface driver rtl8187
[ 22.242553] usbcore: registered new interface driver rndis_wlan
[ 22.248779] usbcore: registered new interface driver zd1201
[ 22.254760] usbcore: registered new interface driver usb8xxx
[ 22.260711] usbcore: registered new interface driver rt2500usb
[ 22.266906] usbcore: registered new interface driver rt73usb
[ 22.272918] usbcore: registered new interface driver p54usb
[ 22.278564] i2c /dev entries driver
[ 22.283538] Driver 'sd' needs updating - please use bus_type
methods
[ 22.290252] Driver 'sr' needs updating - please use bus_type
methods
[ 22.297607] omap2-nand driver initializing
[ 22.302093] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba
(Micron NAND 256MiB 1,8V 16-bit)
[ 22.311096] cmdlinepart partition parsing not available
[ 22.316406] Creating 5 MTD partitions on "omap2-nand":
[ 22.321594] 0x000000000000-0x000000080000 : "X-Loader"
[ 22.328521] 0x000000080000-0x000000260000 : "U-Boot"
[ 22.335449] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 22.342041] 0x000000280000-0x000000680000 : "Kernel"
[ 22.349822] 0x000000680000-0x000010000000 : "File System"
[ 22.461090] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI)
Driver
[ 22.468078] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 22.474731] ehci-omap ehci-omap.0: new USB bus registered, assigned
bus number 1
[ 22.482543] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 22.503570] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 22.510131] usb usb1: configuration #1 chosen from 1 choice
[ 22.516235] hub 1-0:1.0: USB hub found
[ 22.520141] hub 1-0:1.0: 3 ports detected
[ 22.526184] Initializing USB Mass Storage driver...
[ 22.531524] usbcore: registered new interface driver usb-storage
[ 22.537628] USB Mass Storage support registered.
[ 22.542968] mice: PS/2 mouse device common for all mice
[ 22.548858] input: gpio-keys as /class/input/input0
[ 22.556091] input: twl4030_pwrbutton as /class/input/input1
[ 22.563079] twl4030_rtc twl4030_rtc: rtc core: registered
twl4030_rtc as rtc0
[ 22.570434] twl4030_rtc twl4030_rtc: Power up reset detected.
[ 22.576629] twl4030_rtc twl4030_rtc: Enabling TWL4030-RTC.
[ 22.584320] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 22.590728] Bluetooth: HCI UART driver ver 2.2
[ 22.595214] Bluetooth: HCI H4 protocol initialized
[ 22.600067] Bluetooth: HCI BCSP protocol initialized
[ 22.605072] Bluetooth: HCILL protocol initialized
[ 22.609832] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[ 22.616271] usbcore: registered new interface driver bcm203x
[ 22.622039] Bluetooth: Digianswer Bluetooth USB driver ver 0.10
[ 22.628326] usbcore: registered new interface driver bpa10x
[ 22.634033] Bluetooth: BlueFRITZ! USB driver ver 1.2
[ 22.639312] usbcore: registered new interface driver bfusb
[ 22.644897] Bluetooth: Generic Bluetooth USB driver ver 0.4
[ 22.650756] usbcore: registered new interface driver btusb
[ 22.656341] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 22.663116] mmci-omap-hs mmci-omap-hs.0: Failed to get debounce
clock
[ 22.778472] Registered led device: beagleboard::usr0
[ 22.783874] Registered led device: beagleboard::usr1
[ 22.795196] usbcore: registered new interface driver usbhid
[ 22.800903] usbhid: v2.6:USB HID core driver
[ 22.806274] Advanced Linux Sound Architecture Driver Version
1.0.18a.
[ 22.813598] usbcore: registered new interface driver snd-usb-audio
[ 22.820281] No device for DAI twl4030
[ 22.824035] No device for DAI omap-mcbsp-dai-0
[ 22.828521] No device for DAI omap-mcbsp-dai-1
[ 22.833099] No device for DAI omap-mcbsp-dai-2
[ 22.837585] No device for DAI omap-mcbsp-dai-3
[ 22.842071] No device for DAI omap-mcbsp-dai-4
[ 22.846557] OMAP3 Beagle SoC init
[ 22.850280] usb 1-2: new high speed USB device using ehci-omap and
address 2
[ 22.857574] TWL4030 Audio Codec init
[ 22.862823] asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
[ 22.877899] ALSA device list:
[ 22.880981] #0: omap3beagle (twl4030)
[ 22.885284] oprofile: using arm/armv7
[ 22.889251] TCP cubic registered
[ 22.892517] NET: Registered protocol family 17
[ 22.897064] NET: Registered protocol family 15
[ 22.901580] Bluetooth: L2CAP ver 2.11
[ 22.905303] Bluetooth: L2CAP socket layer initialized
[ 22.910430] Bluetooth: SCO (Voice Link) ver 0.6
[ 22.914978] Bluetooth: SCO socket layer initialized
[ 22.925506] Bluetooth: RFCOMM socket layer initialized
[ 22.930725] Bluetooth: RFCOMM TTY layer initialized
[ 22.935729] Bluetooth: RFCOMM ver 1.10
[ 22.939514] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 22.944885] Bluetooth: BNEP filters: protocol multicast
[ 22.950164] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 22.959350] RPC: Registered udp transport module.
[ 22.964080] RPC: Registered tcp transport module.
[ 22.968902] lib80211: common routines for IEEE802.11 drivers
[ 22.974700] ThumbEE CPU extension supported.
[ 22.979003] Power Management for TI OMAP3.
[ 22.983673] SmartReflex driver initialized
[ 22.995056] Disabling unused clock "sr2_fck"
[ 22.999481] Disabling unused clock "sr1_fck"
[ 23.003814] Disabling unused clock "mcbsp_fck"
[ 23.008300] Disabling unused clock "mcbsp_fck"
[ 23.012817] Disabling unused clock "mcbsp_fck"
[ 23.017272] Disabling unused clock "mcbsp_ick"
[ 23.021789] Disabling unused clock "mcbsp_ick"
[ 23.026275] Disabling unused clock "mcbsp_ick"
[ 23.030761] Disabling unused clock "gpt2_ick"
[ 23.035186] Disabling unused clock "gpt3_ick"
[ 23.039581] Disabling unused clock "gpt4_ick"
[ 23.043975] Disabling unused clock "gpt5_ick"
[ 23.048370] Disabling unused clock "gpt6_ick"
[ 23.052764] Disabling unused clock "gpt7_ick"
[ 23.057159] Disabling unused clock "gpt8_ick"
[ 23.061553] Disabling unused clock "gpt9_ick"
[ 23.065948] Disabling unused clock "wdt3_ick"
[ 23.070343] Disabling unused clock "wdt3_fck"
[ 23.074768] Disabling unused clock "gpio2_dbck"
[ 23.079315] Disabling unused clock "gpio3_dbck"
[ 23.083923] Disabling unused clock "gpio4_dbck"
[ 23.088470] Disabling unused clock "gpio5_dbck"
[ 23.093048] Disabling unused clock "gpio6_dbck"
[ 23.097656] Disabling unused clock "gpt9_fck"
[ 23.102020] Disabling unused clock "gpt8_fck"
[ 23.106445] Disabling unused clock "gpt7_fck"
[ 23.110839] Disabling unused clock "gpt6_fck"
[ 23.115234] Disabling unused clock "gpt5_fck"
[ 23.119628] Disabling unused clock "gpt4_fck"
[ 23.124023] Disabling unused clock "gpt3_fck"
[ 23.128417] Disabling unused clock "gpt2_fck"
[ 23.132812] Disabling unused clock "gpt1_ick"
[ 23.137237] Disabling unused clock "wdt1_ick"
[ 23.141632] Disabling unused clock "wdt2_ick"
[ 23.146026] Disabling unused clock "wdt2_fck"
[ 23.150421] Disabling unused clock "gpio1_dbck"
[ 23.154998] Disabling unused clock "gpt1_fck"
[ 23.159393] Disabling unused clock "cam_ick"
[ 23.163757] Disabling unused clock "cam_mclk"
[ 23.168182] Disabling unused clock "des1_ick"
[ 23.172576] Disabling unused clock "sha11_ick"
[ 23.177062] Disabling unused clock "rng_ick"
[ 23.181365] Disabling unused clock "aes1_ick"
[ 23.185760] Disabling unused clock "ssi_ick"
[ 23.190063] Disabling unused clock "mailboxes_ick"
[ 23.194915] Disabling unused clock "mcbsp_ick"
[ 23.199401] Disabling unused clock "mcbsp_ick"
[ 23.203887] Disabling unused clock "gpt10_ick"
[ 23.208374] Disabling unused clock "gpt11_ick"
[ 23.212860] Disabling unused clock "i2c_ick"
[ 23.217163] Disabling unused clock "mcspi_ick"
[ 23.221649] Disabling unused clock "mcspi_ick"
[ 23.226135] Disabling unused clock "mcspi_ick"
[ 23.230651] Disabling unused clock "mcspi_ick"
[ 23.235107] Disabling unused clock "hdq_ick"
[ 23.239440] Disabling unused clock "mspro_ick"
[ 23.243896] Disabling unused clock "des2_ick"
[ 23.248321] Disabling unused clock "sha12_ick"
[ 23.252777] Disabling unused clock "aes2_ick"
[ 23.257202] Disabling unused clock "icr_ick"
[ 23.261505] Disabling unused clock "pka_ick"
[ 23.265808] Disabling unused clock "ssi_ssr_fck"
[ 23.270477] Disabling unused clock "hdq_fck"
[ 23.274780] Disabling unused clock "mcspi_fck"
[ 23.279296] Disabling unused clock "mcspi_fck"
[ 23.283752] Disabling unused clock "mcspi_fck"
[ 23.288238] Disabling unused clock "mcspi_fck"
[ 23.292755] Disabling unused clock "mcbsp_fck"
[ 23.297210] Disabling unused clock "mcbsp_fck"
[ 23.301696] Disabling unused clock "i2c_fck"
[ 23.305999] Disabling unused clock "mspro_fck"
[ 23.310516] Disabling unused clock "gpt11_fck"
[ 23.314971] Disabling unused clock "gpt10_fck"
[ 23.319488] Disabling unused clock "dpll4_m6x2_ck"
[ 23.324310] Disabling unused clock "dpll3_m3x2_ck"
[ 23.329132] Disabling unused clock "sys_clkout1"
[ 23.333862] VFP support v0.3: implementor 41 architecture 3 part 30
variant c rev 1
[ 23.347625] registered taskstats version 1
[ 23.371887] Console: switching to colour frame buffer device 80x30
[ 23.389251] clock: clksel_round_rate_div: dpll4_m4_ck target_rate
48000000
[ 23.396179] clock: new_div = 9, new_rate = 48000000
[ 23.410644] usb 1-2: configuration #1 chosen from 1 choice
[ 23.416961] twl4030_rtc twl4030_rtc: setting system clock to
2000-01-01 00:00:00 UTC (946684800)
[ 23.426055] hub 1-2:1.0: USB hub found
[ 23.430206] hub 1-2:1.0: 4 ports detected
[ 23.449035] mmc0: new high speed SD card at address b368
[ 23.455017] mmcblk0: mmc0:b368 SD 1.88 GiB
[ 23.459838] mmcblk0: p1 p2
[ 23.724273] usb 1-2.1: new high speed USB device using ehci-omap
and address 3
[ 24.020874] usb 1-2.1: configuration #1 chosen from 1 choice
[ 24.137573] phy0 -> rt2500usb_init_eeprom: Error - Invalid RT
chipset detected.
[ 24.144958] phy0 -> rt2x00lib_probe_dev: Error - Failed to allocate
device.
[ 24.415802] wmaster0 (rt73usb): not using net_device_ops yet
[ 24.423187] wlan0 (rt73usb): not using net_device_ops yet
[ 24.429962] Registered led device: rt73usb-phy1:radio
[ 24.435455] Registered led device: rt73usb-phy1:assoc
[ 24.440856] Registered led device: rt73usb-phy1:quality
[ 24.535308] usb 1-2.3: new high speed USB device using ehci-omap
and address 4
[ 24.663574] usb 1-2.3: configuration #1 chosen from 1 choice
[ 24.670227] hub 1-2.3:1.0: USB hub found
[ 24.674560] hub 1-2.3:1.0: 4 ports detected
[ 24.965057] usb 1-2.3.2: new high speed USB device using ehci-omap
and address 5
[ 25.219360] usb 1-2.3.2: configuration #1 chosen from 1 choice
[ 25.226165] invalid HEADER
[ 25.228942] snd-usb-audio: probe of 1-2.3.2:1.0 failed with error
-5
[ 25.236511] invalid HEADER
[ 25.239410] snd-usb-audio: probe of 1-2.3.2:1.1 failed with error
-5
[ 25.355590] usb 1-2.3.3: new low speed USB device using ehci-omap
and address 6
[ 25.485626] usb 1-2.3.3: configuration #1 chosen from 1 choice
[ 25.497039] input: Dell Dell USB Optical Mouse as /class/input/
input2
[ 25.504577] generic-usb 0003:413C:3012.0001: input: USB HID v1.11
Mouse [Dell Dell USB Optical Mouse] on usb-ehci-omap.0-2.3.3/input0
[ 25.598052] usb 1-2.3.4: new low speed USB device using ehci-omap
and address 7
[ 25.729766] usb 1-2.3.4: configuration #1 chosen from 1 choice
[ 25.743041] input: Dell Dell USB Keyboard as /class/input/input3
[ 25.750640] generic-usb 0003:413C:2003.0002: input: USB HID v1.10
Keyboard [Dell Dell USB Keyboard] on usb-ehci-omap.0-2.3.4/input0
[ 27.173004] kjournald starting. Commit interval 5 seconds
[ 27.345947] EXT3 FS on mmcblk0p2, internal journal
[ 27.350799] EXT3-fs: recovery complete.
[ 27.360198] EXT3-fs: mounted filesystem with ordered data mode.
[ 27.366241] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 27.372497] Freeing init memory: 204K
INIT: version 2.86 booting
Please wait: booting...
Starting udev[ 29.378112] uncorrectable error : <3>end_request: I/O
error, dev mtdblock0, sector 0
[ 29.386016] Buffer I/O error on device mtdblock0, logical block 0
[ 29.392822] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 8
[ 29.400665] Buffer I/O error on device mtdblock0, logical block 1
[ 29.406951] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 16
[ 29.414886] Buffer I/O error on device mtdblock0, logical block 2
[ 29.421173] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 24
[ 29.429077] Buffer I/O error on device mtdblock0, logical block 3
[ 30.363311] uncorrectable error : <3>end_request: I/O error, dev
mtdblock0, sector 0
[ 30.371124] Buffer I/O error on device mtdblock0, logical block 0
[ 36.978332] Linux video capture interface: v2.00
[ 37.069915] uvcvideo: Found UVC 1.00 device <unnamed> (046d:0990)
[ 37.133789] input: UVC Camera (046d:0990) as /class/input/input4
[ 37.140441] usbcore: registered new interface driver uvcvideo
[ 37.146392] USB Video Class driver (v0.1.0)
and populating dev cache
Remounting root file system...
[ 39.685577] NET: Registered protocol family 10
[ 39.779479] NET: Registered protocol family 23
[ 39.814178] IrCOMM protocol (Dag Brattli)
Unknown HZ value! (68) Assume 100.
ALSA: Restoring mixer settings...
/usr/sbin/alsactl: parse:1620: Unable to open file '/usr/share/alsa/
init/00main': No such file or directory
/usr/sbin/alsactl: set_control:1266: failed to obtain info for control
#1 (No such file or directory)
#2 (No such file or directory)
No state is present for card Q9000
Configuring network interfaces... eth0: unknown interface: No such
device
eth0: unknown interface: No such device
eth0 No such device
done.
Starting portmap daemon: portmap.
Unknown HZ value! (71) Assume 100.
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
Fri Jun 12 13:06:00 BST 2009
INIT: Entering runlevel: 5
Configuring leds:
beagleboard::usr0: heartbeat
beagleboard::usr1: mmc0
rt73usb-phy1:assoc: none
rt73usb-phy1:qualit: none
rt73usb-phy1:radio: none
Starting Dropbear SSH server: dropbear.
Starting advanced power management daemon: No APM support in kernel
(failed.)
Starting system message bus: dbus.
Starting Hardware abstraction layer hald
Starting syslogd/klogd: done
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
[ ok ]
Starting Connection Manager
Running ntpdate to synchronize clockError : Temporary failure in name
resolution
[ 45.268371] rt73usb 1-2.1:1.0: firmware: requesting rt73.bin
Starting GPE display manager: gpe-dm
[ 45.440002] ADDRCONF(NETDEV_UP): wlan0: link is not ready
> > __ | ---'| '--.| .-'| | |
The Angstrom Distribution beagleboard ttyS2
Angstrom 2009.X-stable beagleboard ttyS2
beagleboard login: root
root@beagleboard:~# [ 95.207000] keyboard.c: can't emulate rawmode
for keycode 212
[ 95.431030] keyboard.c: can't emulate rawmode for keycode 212
[ 95.638977] keyboard.c: can't emulate rawmode for keycode 212
[ 95.799041] keyboard.c: can't emulate rawmode for keycode 212
[ 95.975036] keyboard.c: can't emulate rawmode for keycode 212
[ 96.150970] keyboard.c: can't emulate rawmode for keycode 212
[ 96.359008] keyboard.c: can't emulate rawmode for keycode 212
[ 96.535034] keyboard.c: can't emulate rawmode for keycode 212
[ 100.838958] keyboard.c: can't emulate rawmode for keycode 212
[ 101.030944] keyboard.c: can't emulate rawmode for keycode 212
[ 101.334930] keyboard.c: can't emulate rawmode for keycode 212
[ 101.446990] keyboard.c: can't emulate rawmode for keycode 212
