I need to run a nodejs webserver on BeagleBone and BeagleBone Black. The factory image of Angstrom has an old version not compatible with modules I need (socket.io, serialport, …)
Have a problem with installation from sources. Based on instructions from here: http://www.armhf.com/index.php/node-js-for-the-beaglebone-black/ and here: http://vamfun.wordpress.com/2013/08/09/note-2-beaglebone-blackbuilding-openrov-software-with-angstrom/ I did the following:
root@beaglebone:~# uname -a
Linux beaglebone 3.8.13 #1 SMP Thu Sep 12 10:27:06 CEST 2013 armv7l GNU/Linux
root@beaglebone:~# opkg update
root@beaglebone:~# opkg install g++ curl pkg-config libv4l-dev libjpeg-dev build
-esial libssl-dev vim cmake
Package g++ (linaro-4.7-r9.3) installed in root is up to date.
Package curl (7.26.0-r1.10) installed in root is up to date.
Unknown package ‘pkg-config’.
Package libv4l-dev (0.8.8-r2.7) installed in root is up to date.
Package libjpeg-dev (8d+1.2.1-r2.7) installed in root is up to date.
Unknown package ‘build-essential’.
Unknown package ‘libssl-dev’.
Package vim (7.2.446-r11.3.7) installed in root is up to date.
Package cmake (2.8.8-r0.0.4) installed in root is up to date.
Collected errors:
opkg_install_cmd: Cannot install package pkg-config.
opkg_install_cmd: Cannot install package build-essential.
opkg_install_cmd: Cannot install package libssl-dev.
root@beaglebone:~# opkg install packagegroup-core-buildessential-dev 1.0-r0.4
Package packagegroup-core-buildessential-dev (1.0-r0.4) installed in root is up
to date.
Unknown package ‘1.0-r0.4’.
Collected errors:
- opkg_install_cmd: Cannot install package 1.0-r0.4.
root@beaglebone:~# wget http://nodejs.org/dist/v0.10.20/node-v0.10.20.tar.gz
root@beaglebone:~# tar xzvf node-v0.10.20.tar.gz
root@beaglebone:~# cd node-v0.10.20
root@beaglebone:~/node-v0.10.20#
root@beaglebone:~/node-v0.10.20# ./configure --without-snapshot
Traceback (most recent call last):
File “./configure”, line 14, in
from gyp.common import GetFlavor
File “./tools/gyp/pylib/gyp/init.py”, line 8, in
import gyp.input
File “./tools/gyp/pylib/gyp/input.py”, line 14, in
import gyp.common
File “./tools/gyp/pylib/gyp/common.py”, line 8, in
import filecmp
ImportError: No module named filecmp
Any advice?
Jan
