My current Angstrom is console only, how to install a GUI, such as
X11, on it?
what kind of opkg packages shoule be installed?
Zhen
X11, on it?
Zhen
Hi !
I dont exactly know about the packages which need to be installed
but if you want to start afresh, then you can download the bootloader
files (MLO, u-boot.bin) as usual from http://www.angstrom-distribution.org/demo/beagleboard
and the filesystem (which has a GUI) from :
http://www.angstrom-distribution.org/demo/beagleboard/Angstrom-Beagleboard-demo-image-glibc-ipk-2011.1-beagleboard.rootfs.tar.bz2.
After untarring the filesystem, the uImage file should be copied from
the /boot directory to the boot partition of the SD/MicroSD Card.
Cheers !
I chose xfce4 from Narcissus and then issued the following after
logging in as root:
root:~# opkg install angstrom-x11-base-depends
root:~# startxfce4
Mark
