I am currently on step 5A on this page
http://www.vesperix.com/arm/atlas-arm/source/index.html
I will soon compile this library for the DSP’s C64 architecture. The objective is to use this library in tandem with the main BLAS application (running on the main ARM CPU). I was wondering how I should go about loading the library into the DSP’s memory before (or, if necessary, during) running the application.
Note: I am capable of using a serial connection to another machine where I can store the library before loading it onto the Beagleboard, if that is useful.
I will soon compile this library for the DSP's C64 architecture. The objective is to use this library in tandem with the
DSP's memory before (or, if necessary, during) running the application.
one does not simply load a library into the DSP
you need some kind of framework running on the DSP that
will load firmware and handle the ARM<->DSP communication.
Have a look at DSPLink:
http://processors.wiki.ti.com/index.php/DSPLink_FAQs
http://ossie.wireless.vt.edu/trac/wiki/BeagleBoard_DSPLink
http://ossie.wireless.vt.edu/trac/wiki/BeagleBoard_CodecEngine
and/or C6Run:
http://processors.wiki.ti.com/index.php/C6EZRun
Wow. These links look to be extremely helpful. I’ll definitely try out the tools. Thanks for the info!
