How to Login into beagleboard-xm through GUI mode.
I am currently using DVI-D to HDMI cable to connect beagleboard-xm to monitor but, the problem is when i connect beagleboard-xm to monitor the board boots in terminal mode instead to GUI mode.
If anyone knows solutions for this please do help.
thanks in prior
Did the "image" you installed to the board, actually promis a gui in
the notes? Or did you just install a console/minimal image? In which
case you need to install the gui yourself..
