How to make an image ?
Hello All;
I believe this questions has been asked before, but I don’t recall an answer.
I am using the latest Debian image as a starting point and have installed a number of additional tool in rootfs.
I am using an 8GB uSD card but the roof file system takes up less than 4GB.
What I am trying to do is to create an image that is about 4GB and includes the boot partition plus the used portion of rootfs.
I researched the “DD” command, but if I understand correctly, I would end up with an 8GB image.
I know that I can use “tar” to create an archive of the boot/rootfs partitions, but that isn’t an “image”.
I suppose I could just modify one of Robert Nelson’s scripts to automatically format and copy a uSD card, but I am wondering
If there is a better way ?
Thanks;
Bill
“No one could make a greater mistake than he who did nothing because he could do only a little.”
“All that is necessary for the triumph of evil is that good men do nothing” Edmond Burke (1729 - 1797)
http://www.packtpub.com/building-a-home-security-system-with-beaglebone/book
I use tar and the substitute my rootfs archive for Robert’s and reuse his scripts. I don’t store to emmc though, so it may be different for your case.
Thanks Philip, that’s what I was after.
( I don’t write to emmc either J)
Thanks again Philip;
I can’t find my old scripts that I used to use and I couldn’t find
The originals, using Google.
Most of the links point to burning an image or step by step and not Robert’s script.
I looked in the obvious(?) spot on his git hub L
Bill
