How to make audio working in kernel from code.google.com
I have BB Rev.C2 board and u-boot,x-load and kernel sources from
http://code.google.com/p/beagleboard/wiki/BeagleSourceCode
Tool chain installed is 2007q3 from CodeSourcery.
I am newbie to OMAP and BB.
I would like to develop a simple application that can play wav file or
small amount of predefined data from buffer.
Could you please help me
1. what are the options I have to select in kernel with " make
menuconfig "
2. Is there any driver available in kernel
3. what is driver and where it is in kernel
4. Is there any guidelines/ docs available for audio codec to use
5. what are the things to be done in application and kernel
Thanks in advance
use http://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidation
Follow Steps given for audio out/in validation.
Khasim
Hi Khasim,
u-boot,x-load and kernel sources I have downloaded from
http://code.google.com/p/beagleboard/wiki/BeagleSourceCode .
Not from git links given in http://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidation
Is default configuration enough for enabling audio drivers in the
above kernel from http://code.google.com/p/beagleboard/wiki/BeagleSourceCode
or
do I need to do some thing else ??
It would be more helpful for me if you can clarify my doubts mentioned
in the previous mail.
Thanks in advance.
Hi Khasim,
u-boot,x-load and kernel sources I have downloaded fromhttp://code.google.com/p/beagleboard/wiki/BeagleSourceCode.
Not from git links given inhttp://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidation
above kernel fromhttp://code.google.com/p/beagleboard/wiki/BeagleSourceCode
or
Thanks in advance.
> usehttp://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidation
I could not hear any sound from recorded file for audio IN test on BB.
Also checked playback of recorded file in PC but there also no sound.
What could be the problem?
also contains pre-built images for u-boot xloader and kernel, I
suggest you use these instead of old one.
Yes, default config is good enough for Audio in/out drivers.
Khasim
I downloaded pre-built images for validation from
http://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidation.
I followed the instructions given in the above link. I tried to
validate Audio-In and Audio-Out in BB but I did not hear audio from
Audio-Out line of BB but it is only noise sound.
Of course I also tried the recorded file play in PC but nothing
audible it is only noise...
I have connected the UART cable to PC, SDcard to BB, Audio-In cable
from PC and Audio-Out to self powered speakers.
Then I connected USB cable from OTG port of BB to Host port of PC
while pressing USER button and I followed the instructions given in
the above link.
Also I would like to have sources of pre-built images and kindly tell
me
1. how I can get those sources from windows PC ( some of the links
given are not active)
http://git.gitorious.org/x-load-omap3/mainline.git
http://git.gitorious.org/beagleboard/mainline.git
2. guide to build the sources
3. Can I use same toolchain arm-2007q3-51-arm-none-linux-gnueabi-i686-
pc-linux-gnu.tar.bz2 form codesourcery ? if any any other pls mention
TIA
Can you run the mplayer test it should play audio on speakers and video on DVI.
can someone help me how to put in ethernet beagleboard
Khasim:
Able to hear audio if I run mplayer.
Right now I am not bothering about video playback but how to make
audio playback on BB ( at least .wav file ).
can you help me by giving right pointers to my previous/above mail ?
It will be more helpful for me.
TIA
Khasim:
TIA
Can anyone help on this?
Your help is appreciated.
TIA
