Hi Robert Nelson
Thanks for your response.
I build the new dtbo file on Beagleboard successfully. But when I use this dtbo file on booting I got the error as below.
Starting kernel …
[ 0.000892] clocksource_probe: no matching clocksources found
[ 2.096964] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 2.125373] pinctrl-single 44e10800.pinmux: pin 44e10934.0 already requested by 481a6000.serial; cannot claim for 4a100000.ethernet
[ 2.137394] pinctrl-single 44e10800.pinmux: pin-77 (4a100000.ethernet) status -22
[ 2.144945] pinctrl-single 44e10800.pinmux: could not request pin 77 (44e10934.0) from group cpsw_default on device pinctrl-single
[ 2.156845] cpsw 4a100000.ethernet: Error applying setting, reverse things back
[ 2.178149] pinctrl-single 44e10800.pinmux: pin 44e10948.0 already requested by 481a6000.serial; cannot claim for 4a101000.mdio
[ 2.189749] pinctrl-single 44e10800.pinmux: pin-82 (4a101000.mdio) status -22
[ 2.196939] pinctrl-single 44e10800.pinmux: could not request pin 82 (44e10948.0) from group davinci_mdio_default on device pinctrl-single
[ 2.209533] davinci_mdio 4a101000.mdio: Error applying setting, reverse things back
[ 2.349675] davinci_mdio 4a101000.mdio: timed out waiting for user access
[ 2.453669] davinci_mdio 4a101000.mdio: timed out waiting for idle
[ 2.709227] omap_voltage_late_init: Voltage driver support not added
[ 2.717437] PM: Cannot get wkup_m3_ipc handle
rootfs: clean, 76605/217728 files, 442372/869376 blocks
[ 15.337565] libphy: PHY 4a101000.mdio:00 not found
[ 15.342459] net eth0: phy “4a101000.mdio:00” not found on slave 0, err -19
Debian GNU/Linux 9 beaglebone ttyS0
BeagleBoard.org Debian Image 2017-10-10
Support/FAQ: Beagleboard:BeagleBoneBlack Debian - eLinux.org
default username:password is [debian:temppwd]
beaglebone login:
I could find the eth0 interface in linux but it couldn’t work. And the wlan0 works well.
debian@beaglebone:~$ ifconfig
SoftAp0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.8.1 netmask 255.255.255.0 broadcast 192.168.8.255
inet6 fe80::8230:dcff:fe73:8e71 prefixlen 64 scopeid 0x20
ether 80:30:dc:73:8e:71 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 30 bytes 6385 (6.2 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
eth0: flags=-28669<UP,BROADCAST,MULTICAST,DYNAMIC> mtu 1500
TX packets 0 bytes 0 (0.0 B)
device interrupt 175
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1 (Local Loopback)
RX packets 1760 bytes 122400 (119.5 KiB)
TX packets 1760 bytes 122400 (119.5 KiB)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.7.2 netmask 255.255.255.252 broadcast 192.168.7.3
ether 80:30:dc:73:8e:73 txqueuelen 1000 (Ethernet)
usb1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.6.2 netmask 255.255.255.252 broadcast 192.168.6.3
ether 80:30:dc:73:8e:76 txqueuelen 1000 (Ethernet)
wlan0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 10.0.0.13 netmask 255.255.255.0 broadcast 10.0.0.255
inet6 fe80::7a5c:78ff:fe78:785c prefixlen 64 scopeid 0x20
ether 78:5c:78:78:78:5c txqueuelen 1000 (Ethernet)
RX packets 54 bytes 8090 (7.9 KiB)
TX packets 82 bytes 18671 (18.2 KiB)
Would you like to help me to figure it out? Thank you very much.
