I have a linux 5.4 custom build (by BuildRoot) for BeagleBone Black. There is no device-tree overlay and cape manager…
I need some inputs and outputs so I should create a patch for the am335x-boneblack-common.dtsi file (and probably for am335x-boneblack.dts too) that’s way I have added some lines to am335x-boneblack-commom.dtsi into the “&am33xx_pinmux” section:
&am33xx_pinmux {
gpio_pins: pinmux_gpio_pins {
pinctrl-single,pins = <
AM33XX_PADCONF(AM335X_PIN_MCASP0_FSR, PIN_OUTPUT, MUX_MODE7) /* control pin1 /
AM33XX_PADCONF(AM335X_PIN_GPMC_A1, PIN_OUTPUT, MUX_MODE7) / control pin2 */
AM33XX_PADCONF(AM335X_PIN_GPMC_OEN_REN, PIN_INPUT_PULLUP, MUX_MODE7) /* SW1 /
AM33XX_PADCONF(AM335X_PIN_GPMC_ADVN_ALE, PIN_INPUT_PULLUP, MUX_MODE7) / SW2 /
AM33XX_PADCONF(AM335X_PIN_GPMC_WEN, PIN_INPUT_PULLUP, MUX_MODE7) / SW3 /
AM33XX_PADCONF(AM335X_PIN_GPMC_BEN0_CLE, PIN_INPUT_PULLUP, MUX_MODE7) / SW4 */
AM33XX_PADCONF(AM335X_PIN_GPMC_CSN0, PIN_INPUT_PULLUP, MUX_MODE7) /* Rev0 /
AM33XX_PADCONF(AM335X_PIN_GPMC_CLK, PIN_INPUT_PULLUP, MUX_MODE7) / Rev1 */
AM33XX_PADCONF(AM335X_PIN_GPMC_AD10, PIN_INPUT_PULLUP, MUX_MODE7) /* input1 /
AM33XX_PADCONF(AM335X_PIN_GPMC_AD15, PIN_INPUT_PULLUP, MUX_MODE7) / input2 /
AM33XX_PADCONF(AM335X_PIN_GPMC_AD14, PIN_INPUT_PULLUP, MUX_MODE7) / input3 /
AM33XX_PADCONF(AM335X_PIN_GPMC_AD11, PIN_INPUT_PULLUP, MUX_MODE7) / input4 */
It has no effect. The “input pull up” does not work. I have read a lot of articles and projects, but I don’t know how I should do it.I have stucked here.
Please help me with an example or any other way to make those inputs and outputs work .
Thank you in advance.
