How to properly update my application
I have a Qt application that runs at start up. Currently, I update my application by allowing the user to press a button inside of my application which copies the updated application files from the USB drive to the eMMC. It then sets a flag inside of a text file to “1”, and reboots. When my start up script is ran, it firsts checks the text file to see if there is a “1”, and if so it overwrites the old files with the new ones and then launches the application. This works most of the time, but there are occasions where something gets messed up and the new application does not start.
I was wondering if there is a better way of updating my application. Could I use opkg to do this, and if so, how? Will it allow my application to be running while it is updating it? What is the proper way to do this? Thanks in advance for your help!
Define “something gets messed up”. You’re going to have to know what this something is before solving the issue. But perhaps you could use an MD5 sum to verify the file ? Then when there is a mismatch you delete the target file and try again ?
I can’t quite define it, but something seems to get corrupted. When the new “corrupted” application runs, it only shows a white rectangle, rather than the application. I guess I was wondering how others update their own software applications - if they do something similar to what I’m doing or if they are using opkg/apt-get/etc. The MD5 sum may be something I could look into… I’m not familiar on how to implement that, but I’ll do some research. Thanks,
I haven’t done this myself, but it is something I am looking into as I was planning to create a QT5 package for Debian. Here is a good reference:
http://www.debian.org/doc/manuals/maint-guide/
I’ve seen Debian application update while they are open and the new version is used the next time the application is launched, and I’ve seen application update from within the application and then relaunch when the update is complete.
John
I can't quite define it, but something seems to get corrupted. When the
new "corrupted" application runs, it only shows a white rectangle, rather
software applications - if they do something similar to what I'm doing or
look into... I'm not familiar on how to implement that, but I'll do some
research. Thanks,
I've gotten frustrated with corrupt root filesystems enough that I keep
mine read-only and ping-pong the firmware updates between two partitions.
I.e., the BBB starts out booting off the rootfs in the 2nd partition
(uboot, etc are in the 1st). The updater writes the new rootfs to the 3rd
partition and then when it's done, the 3rd partition becomes the new active
one. I keep all of my application data on a writable 4th partition so that
it doesn't get overwritten by the firmware updates. This setup is a bit old
school, but it has worked well for me. I also don't usually have access to
devices to investigate corruption issues, so it can be hard to figure out
the root cause.
I use Buildroot to create my root filesystems. For an open-source project
that I'm working on, I had to put together a firmware update utility to
manage updates. It seems to work for me and for what I need on the other
project, but it's not battle tested (the battle tested one is tied to a
product). If you're interested, you can look at it here:
GitHub - fwup-home/fwup: Configurable embedded Linux firmware update creator and runner. I just updated an example project to show
how it can be used on the BBB:
GitHub - fhunleth/bbb-buildroot-fwup: Example project showing how to use buildroot and fwup.
Frank
The MD5 sum seems like a good approach. For anyone reading this, I found this link useful:
http://askubuntu.com/questions/318530/generate-md5-checksum-for-all-files-in-a-directory
find -exec md5sum "{}" \; > checklist.chk
Now hopefully, your issue is related to corrupt or otherwise unusable file.
