how to read ADC analog value in newer kernel 4.1.3-ti-r6
After I upgrade my kernel to 4.1.3-ti-r6.
I try to use ADC utility in adafruit-beaglebone-io-python, the following error popups, but GPIO utility of the library is okay.
anything wrong?
import Adafruit_BBIO.ADC as ADC
ADC.setup()
Traceback (most recent call last):
File “”, line 1, in
RuntimeError: Unable to setup ADC system. Possible causes are:
  • A cape with a conflicting pin mapping is loaded
  • A device tree object is loaded that uses the same name for a fragment: helper
Anything I need to migrate if the kernel is migrated to 4.1.3-ti-r6 from 3.8.13.bone73 ??
thanks
Ivan
Have you activated (PinMuxed) the pins correctly? Use the dtb-rebuilder of Robert Nelson if not.
https://github.com/RobertCNelson/dtb-rebuilder/blob/4.1.x/src/arm/am335x-boneblack.dts
1.) Add the following lines within the am335x-boneblack.dts file to activate all ADC pins.
& tscadc {
status = " okay ";
& am335x_adc {
ti , adc - channels = <0 1 2 3 4 5 6 7 >;
  1. Make and Make install command within the dtb-rebuilder folder
After a reboot you can check if the ADC pins are activated properly by the following procedure:
root@arm : cd / sys / bus / iio / devices / iio : device0
root@arm :confused: sys / bus / iio / devices / iio : device0 # ls -l
-rw -r - -r - - 1 root root 4096 Aug 13 15:45 in_voltage0_raw
-rw -r - -r - - 1 root root 4096 Aug 13 15:45 in_voltage1_raw
-rw -r - -r - - 1 root root 4096 Aug 13 15:45 in_voltage2_raw
-rw -r - -r - - 1 root root 4096 Aug 13 15:45 in_voltage3_raw
-rw -r - -r - - 1 root root 4096 Aug 13 15:45 in_voltage4_raw
-rw -r - -r - - 1 root root 4096 Aug 13 15:45 in_voltage5_raw
-rw -r - -r - - 1 root root 4096 Aug 13 15:45 in_voltage6_raw
-rw -r - -r - - 1 root root 4096 Aug 13 15:45 in_voltage7_raw
If you see something like that, the pins are activated correctly. you can measure them with cat in_voltageX_raw…
Regards
Benjamin
The Adafruit library isn't ready for v4.1.x...
Make sure you install:
https://github.com/beagleboard/bb.org-overlays
and run:
./dtc-overlay.sh
./install.sh
Then you just:
sudo sh -c "echo 'BB-ADC' > /sys/devices/platform/bone_capemgr/slots"
