I’ve browsed the group looking for cross-compiling Ralink WIFI drivers for the BeagleBoard xM or other Beagle platforms, but couldn’t find a good guide on this.
I need to cross-compile the Ralink 5370 staging drivers (DPO_RT5572_LinuxSTA_2.6.1.3_20121022) from a Ubuntu host on a BBxM with custom Kernel (this: https://ccrma.stanford.edu/~eberdahl/Satellite/). I’ve been given the kernel sources (it’s 3.2.30-x4) and I already succeeded in compiling a Realtek USB dongle kernel module (based on rtl8192cu). My toolchain is based on code sourcery arm-none-linux-gnueabi
However, differently from the Realtek one, the Ralink package has a ugly makefile and thus:
1- if I leave the CFLAGS to the default it will go for normal x86 compile and the arm gcc toolchain won’t recognize x86 related flags (of course)
2- If I attempt to change the CFLAGS, I get the following error:
make[1]: Entering directory `/mnt/DATA/UNIVPM/TECHNICAL/beagleboard/SatelliteCCRMA/SatelliteCCRMA-Berdahl-Kernel-3.2.30-x14_img1.0.1’
scripts/Makefile.build:49: *** CFLAGS was changed in “/mnt/DATA/UNIVPM/TECHNICAL/beagleboard/ZZRALINK2012/DPO_RT5572_LinuxSTA_2.6.1.3_20121022/os/linux/Makefile”. Fix it to use ccflags-y. Stop.
I’ve gone through reading about ccflags-y on the kernel docs, but couldn’t figure out how to apply this here, and on the other side, I can just guess what gcc flags are good to compile this driver on the beagle (e.g. march=armv7-a) but I’m not expert enough to guess them all right. It will take months to guess them ok.
Some insight on this or past experience would be helpful.
Thanks, L
