Can somebody point me at the procedure for restoring the uSD card that
came with my BeagleBoard to its factory configuration?
Searching around, I came across the very promising wiki page:
http://elinux.org/BeagleBoardRecovery
which points me at the even more promising Google Code page
http://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidation
which says that the xM validation procedure is still under development.
I can dd an image from the uSD card for my 2nd BeagleBoard onto this
one, but I'd like to find the official instructions, if I can.
--wpd
Hi Gerald,
I followed these instructions for my BeagleBoard-xM rev A. I wrote BeagleBoard-xM xMTEST_Beta_4_25 on the SD card.
Linux boots, and I see the login window. Then, it restarts. I am powering the board with an external 600mA power supply.
What can be the cause?
best wishes,
2011/11/3 Gerald Coley <gerald@beagleboard.org>
Get a bigger power supply. 600mA is not enough. Go at least 1.2A preferably 2A if you plan to use the USB ports…
2A if you plan to use the USB ports..
Gerald,
I created http://beagleboard.org/peripheral. Can you critique?
Jason
