How to run 2 sripts at the same time?
Goodevening,
Does anybody have an idea how to run these 2 scripts at the same time?
What would be the best way to?
I have tried to activate the 2 scripts with a bashscript, but this gave some weird results.
The goal is that the BBB completes the grafcet and has a blinking green LED to show it’s running.
I know I could just paste running_green under grafcet, but then the timing of the blinking would not be correct.
Here are the 2 python scripts:
Grafcet.py
#!/usr/bin/python
import Adafruit_BBIO.GPIO as GPIO
import time
GPIO.setup(“P8_12”, GPIO.OUT)
GPIO.setup(“P8_14”, GPIO.OUT)
GPIO.setup(“P8_16”, GPIO.OUT)
GPIO.setup(“P8_18”, GPIO.OUT)
GPIO.setup(“P8_11”, GPIO.IN)
GPIO.setup(“P8_13”, GPIO.IN)
GPIO.setup(“P8_15”, GPIO.IN)
GPIO.setup(“P8_17”, GPIO.IN)
GPIO.setup(“P8_19”, GPIO.IN)
X = 0
while True:
stap 1
if GPIO.input(“P8_11”) and X == 0:
GPIO.output(“P8_12”, GPIO.HIGH)
X += 1
print"Step 1: Boiling ingredients"
stap 2
elif GPIO.input(“P8_13”) and X == 1:
GPIO.output(“P8_14”, GPIO.HIGH)
GPIO.output(“P8_12”, GPIO.LOW)
X += 1
print"Step 2: Add yeast and sugar"
elif GPIO.input(“P8_15”) and X == 2:
GPIO.output(“P8_16”, GPIO.HIGH)
GPIO.output(“P8_14”, GPIO.LOW)
X += 1
print"Step 3: fermenting for 6 weeks"
stap 4
elif GPIO.input(“P8_17”) and X == 3:
GPIO.output(“P8_16”, GPIO.LOW)
X = 0
print"End of cycle, beer is ready"
noodstop NC
elif GPIO.input(“P8_19”) == False:
X = 5
print"Emergency button has been activated!"
time.sleep(.1)
running_green.py
#!/usr/bin/python
import time
while True:
time.sleep(.5)
GPIO.output(“P8_18”, GPIO.HIGH)
time.sleep(.5)
GPIO.output(“P8_18”, GPIO.LOW)
Take time.time modulo 1 and not sleep.time, and paste it into one program
eg:
Just run the script in background adding the & in command line.
http://www.thegeekstuff.com/2010/05/unix-background-job/
Thanks Leonard, using the ampersand in a bash script worked.
#!/bin/bash
python grafcet.py &
python running_green.py &
I could only kill the pythons scripts by using the “ps” command (to see the running processes) and “kill” (to stop a process).
The command “jobs” doesn’t seem to work on Angstrom, is this correct?
#!/bin/bash
python grafcet.py &
Correction:
Jobs, fg and bg work on Angstrom.
But when you start the 2 scripts in a bash command:
#!/bin/bash
python grafcet.py &
Jobs cannot catch them.
You can only catch them with jobs, if you start each python script seperately and then use crtl-Z and bg to put the task in the background.
When you do it like so, jobs can see these scripts.
I guess I will have to use threads to start the 2 scripts at the same time and still have control over them.
