how to run fftw on beagleboard
I run fftw bench test application on beagle board. I used Angstrom
2.6.29-omap1 os on beagleboard.
I compile bench test application using CodeSourcery Sourcery_G++_Lite
toolchain.
I set following CFLAGS:
CFLAGS = -O3 -pipe -march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-
abi=softfp -fomit-frame-pointer
When I run fftw bench test application using this command
bench -s ib2048 where i=in-place,b=backward complex transform of
size 2048
bench -s irb2048 where i=in-place,rb=backward real transform of
size 2048
bench -s ob2048 where o=out-of-place,b=backward complex transform
of size 2048
bench -s orb2048 where o=out-of-place,rb=backward real transform of
size 2048
I got result like that,
size setup Time mflops
             Time (ms)
             (ms)
2048 152.80 2.38 47.24 In-place, backward and complex data
2048 399.60 1.47 38.35 In-place, backward and real data
2048 83.53 3.54 31.82 Out-of-place, backward and complex data
2048 218.14 1.48 38.05 Out-of-place, backward and real data
Is it true result ?
Gaurang <gaurang2984@...> writes:
             Time (ms)
             (ms)
Is it true result ?
You received this message because you are subscribed to the Google Groups
"Beagle Board" group.
To post to this group, send email to discussion@...
To unsubscribe from this group, send email to unsubscribe@...
For more options, visit this group at
http://groups.google.com/group/beagleboard?hl=en
Use this recipte:
http://knez.weebly.com/2/post/2013/09/beaglebone-fftw-build.html
and i can make 5000 fftw with 2048 size pes second
