I am trying to set up 2 UARTs using instructions as per http://hipstercircuits.com/enable-serialuarttty-on-beaglebone-black/
except i am also adding another UART, (using the corresponding pin and the pinmux settings for the second file)
I can set up UART3 (ttyO2) & UART5 (ttyO4) independently, and they work fine
However, when loading the 2 device tree sources, only the first pinmux setting seem to be “remembered”, the second are defaulted to 0x37, and therefore do not work
Is there another way of setting up 2 UARTs?
as you can see in the dmesg output below, the pins cannot seem to be setup if there is already UART5 setup
thanks,
Paul
i am using:
Linux beaglebone 3.8.6 #1 SMP
- Copyright © 2012 Texas Instruments Incorporated - http://www.ti.com/
