How to update the latest image to eMMC?
I downloaded the latest image and burn it into SD card. It’s no problem that I boot from SD card. Now, I hope to burn the latest image to eMMC. I followed the instructions of “Flashing eMMC” like below:
In /boot/uEnv.txt:
cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
And then reboot the system. But it seems that the system is blocked for a long time and cannot boot up any more.
I’m using MicroSD16GB, is that a problem?
Any suggestions are appreciated.
Thanks.
do you see the cylon led pattern?
The flashing process is logged over serial and hdmi..
Yes, I think I see the cylon led pattern. Four leds flash one by one and back and forth for about 10 minutes.
And then, all leds flash together. So, I think the image has been burned to eMMC. And then, I restart the board with SD card removed.
And I cannot connect my PC with BBB board via USB. Finally, there is only one led flashing at this time, and no connection appears on my PC.
Could you please tell me what I should do with that?
Thanks a lot.
This is a flash write failure....
What revision of the BBB do you have? B or C?
What image did you try to flash? (full file name)
Are you using a 5volt 1 Amp power supply into the bbb's 5volt jack?
First of all, I’m not using a 5volt 1 Amp power supply into the bbb’s 5jolt jack, only with USB power supply.
Second, the full image file name is: bone-debian-7.8-lxde-4gb-armhf-2015-03-01-4gb.img.
Third, so far I’m not sure which revision of the BBB I have. Could you please tell me how to confirm this?
Thanks a lot.
Do not use USB power to flash. It will fail. USB doe snot provide enough power for the flashing process.
First of all, I'm not using a 5volt 1 Amp power supply into the bbb's
USB Flashing is not supported..
    Third, so far I'm not sure which revision of the BBB I have. Could you
There's a sticker on it..
It'll either say Rev Ax, Rev B, or Rev C..
OK. I’ll try again with 5V power supply. And the revision is Rev C.
Thank you for telling me.
I used 5V power supply and it failed again. What should I do now?
Thanks a lot.
Use the 2015-07-28 wheezy flasher:
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#2015-07-28
I’ll try it tomorrow. Thanks a lot.
