In a wider sense as "todo list" or "open point list"? Or better limit it to something like a "sw bug tracking system"?
Looking to the current entries there (e.g. "New home page"), it seems to be intended to be used in a general way, as "list open points/questions here we don't want to forget".
I would like to use it this way, too. And not limit it to sw bugs only.
Thinking about it, following "open points" come to my mind we could list there:
* How to detect if a Beagle Ax sample still needs a fix for "There is an issue where on some boards the 1.8V has excessive noise on it. This is the result of two incorrect parts being installed on the board."? http://www.beagleboard.org/irclogs/index.php?date=2008-04-28#T19:48:12
Would it be okay to add such stuff to issue tracker? What do you think?
I believe using it in the general sense is a great idea. If we get a
bit overwhelmed and issues don't look like they are being closed, then
we'll find a new approach. Your list of issues below would be good to
include.
How do you think we should use BeagleBoard issue tracker
only.
list there:
include.
include.
