How to write attachInterrupt in BoneScript in details.
Hi, forks!!
I have some questions about attachInterrupt.
I saw the topic
attachInterrupt contents called on startup and stop without event triggered
https://groups.google.com/forum/#!topic/beagleboard/bhacfUnNJYM
Q1:
I think one of solution is check actual button has pushed or not.
b.attachInterrupt(inputPin, true, b.FALLING, interruptCallback);
function interruptCallback() {
if (b.digitalRead(inputPin)===1) return; // Is the real button pushed? or not?
But in this case, the function interruptCallback tightly depend on hardware ,so I can’t reuse it call from another functions (for example WEB interrupt logic).
It seems not good solution.
Is there any solution more smart?
Q2:
http://beagleboard.org/Support/BoneScript/attachInterrupt/
I guess the result of handler can determine to interruptCallback execute or not.
But when my function myhandler always return true, interruptCallback never called…
b.attachInterrupt(inputPin, myhandler, b.FALLING, interruptCallback);
function myhandler(){
return true;
Could you tell me what is wrong, Please!
Thanks.
You could use button.watch() in onoff in place of attachInterrrupt. See https://www.npmjs.org/package/onoff.
