I installed PHP, MySQL 5, and Light TPD on my Beaglebone Black Wireless (running Debian image 2017-07-01). I tried creating a webpage that displays a MySQL table, but noticed that the table wasn’t even appearing. So in order to isolate the problem, I created a simple PHP program that does nothing but display some text and a table with only one row. I began adding things from the larger program one at a time until I found what was causing the tables to disappear. I discovered that the highlighted line is the culprit:
Table Test
<?php
echo "Table Test
// Connecting to the Database
$con = mysqli_connect("localhost","root","Force1$", "AUTO");
//Print HTML table
echo "";
echo "
This code displays the table just fine in an older Beaglebone (Debian image 2015-11-12). I find it hard to believe that simply declaring a variable would cause something like this to happen. Please, any help on this matter would be greatly appreciated. Thank you!
ID |
LOCATION |
SEQUENCE |
TIME |
UPDATE |
DELETE |
On Tue, 18 Jul 2017 10:17:23 -0700 (PDT), Tomas Medina
<tomas@evatech.net> declaimed the following:
No "highlighted line" made it through gmane's server...
culprit:
<html>
<head>
<title>Table Test</title>
<link rel="stylesheet" type="text/css" href="styles.css">
</head>
<BODY>
<p>
<?php
echo "Table Test<br>";
//Print HTML table
echo "<TABLE width=40% cellpadding=5 cellspacing=0 border=1>";
echo "
<TR>
<TD><b>ID</TD>
<TD><b>LOCATION</TD>
<TD><b>SEQUENCE</TD>
<TD><b>TIME</TD>
<TD><b>UPDATE</TD>
<TD><b>DELETE</TD>
</TR>";
</body>
</html>
I don't know PHP, but based upon what came through here -- there is no
logic to fetch/display rows from the database, nor even to end the HTML
TABLE structure. Heck, I'd probably move the contents of the two "echo"
statements out into pure HTML (ie; just
<TABLE ...>
<TR>
<TD>...</TD>
positioned /before/ the <?php )
Putting the table outside of the php marks did solve the invisibility problem. Thank you, I will leave this topic open in case any more problems arise.
