I think, at least w/ the newer images, /dev/bone/i2c/*
are the files to use. Please see here:
https://docs.beagleboard.org/latest/intro/bone101/qwiic-stemma-grove-addons.html#using-i2c-with-linux-drivers
There is a short on i2c drivers in Linux dedicated to the BBB and other boards in general.
P.S. I noticed that there should be sysfs entries/files too but for the SHT21, I found some interesting ideas in the kernel docs.
Humidity¶
humidity[1-*]_input
Humidity.
humidity[1-*]_enable
Enable or disable the sensors.
humidity[1-*]_rated_min
Minimum rated humidity.
humidity[1-*]_rated_max
Maximum rated humidity.
and…
temp[1-*]_type
Sensor type selection.
temp[1-*]_max
Temperature max value.
temp[1-*]_min
Temperature min value.
temp[1-*]_max_hyst
Temperature hysteresis value for max limit.
temp[1-*]_min_hyst
Temperature hysteresis value for min limit.
temp[1-*]_input
Temperature input value.
temp[1-*]_crit
Temperature critical max value, typically greater than corresponding temp_max values.
temp[1-*]_crit_hyst
Temperature hysteresis value for critical limit.
temp[1-*]_emergency
Temperature emergency max value, for chips supporting more than two upper temperature limits.
temp[1-*]_emergency_hyst
Temperature hysteresis value for emergency limit.
temp[1-*]_lcrit
Temperature critical min value, typically lower than corresponding temp_min values.
temp[1-*]_lcrit_hyst
Temperature hysteresis value for critical min limit.
temp[1-*]_offset
Temperature offset which is added to the temperature reading by the chip.
temp[1-*]_label
Suggested temperature channel label.
temp[1-*]_lowest
Historical minimum temperature
temp[1-*]_highest
Historical maximum temperature
temp[1-*]_reset_history
Reset temp_lowest and temp_highest
temp_reset_history
Reset temp_lowest and temp_highest for all sensors
temp[1-*]_enable
temp[1-*]_rated_min
Minimum rated temperature.
temp[1-*]_rated_max
Maximum rated temperature.
Some chips measure temperature using external thermistors and an ADC, and report the temperature measurement as a voltage. Converting this voltage back to a temperature (or the other way around for limits) requires mathematical functions not available in the kernel, so the conversion must occur in user space. For these chips, all temp* files described above should contain values expressed in millivolt instead of millidegree Celsius. In other words, such temperature channels are handled as voltage channels by the driver.
Also see the Alarms section for status flags associated with temperatures.
So, it seems that if the first numerical value 1 in the first link I provided that shows 1 or 2 or 3 or whatever, one can then use this data to handle SHT21 values in their source.
So,
Example1, temp1_max, register is a signed 8 bit value (-128 - 127 degrees):
long v = simple_strtol(buf, NULL, 10) / 1000;
v = clamp_val(v, -128, 127);
/* write v to register */
That is directly from the Linux docs. You will have to get another person to handle the source, i.e. as I am terrible so far w/ source. But! I think these are good pointers for determining the source or echo
commands to use to get started.
