I have build (again) a Robert-Nelson Kernel for my Gentoo on my
Beaglebone.
Unfortunately the boot process hangs, since no ethernet was
found/established/initialized/... and the nfsd hangs forever
waiting for Christmas or whatever.
The default config works...but were can I find it?
And what is the correct procedure if I want to modify
the config and rebuild the kernel after that?
Thank you very much in advance for any help!
Best regards,
mcc
Beaglebone.
via git: (1) https://github.com/RobertCNelson/linux-dev/blob/am33x-v3.2/patches/defconfig
or http (based on version): (2)
http://rcn-ee.net/deb/wheezy-armhf/v3.2.29-psp22/
Use the build scrips in (1)'s repo or just use rebuild using the raw
patchset found in (2)...
Robert Nelson <robertcnelson@gmail.com> [12-09-19 19:00]:
> Hi,
> Beaglebone.
Robert Nelson
http://www.rcn-ee.com/
still haveing problems with the ethernet...
I installed the defconfig again and compiled a kernel based on this
setting. I copied the headers, the modules and the kernel to partition
1 and to partion2/boot as uImage
The kernel itsself boots fine until it tries to fire up eth0 which
fails.
I think that the default config assumes th epreload of certain modules
so that eth0 stuff won't access the nothing.
My question is: What modules do I need to include into the kernel for
a well working ethernet hardware?
(and why does the nfsd seems not to know anything about timeouts and
their correct usage.. ;/ )
Best regards,
mcc
meino.cramer@gmx.de <meino.cramer@gmx.de> [12-09-19 20:44]:
> > Hi,
> > Beaglebone.
> Regards,
> Robert Nelson
fails.
Best regards,
mcc
no...the problem is somewhere else...
If I pull the usb cable (otg, not host) the kernel
boots. As soon as I connect that cable again, the ssh-connection
freezes.
Booting the kernel without the otg usb cable connected works fine and
eth0 comes up -- but I cannot watch the boot process as such.
Booting the kernel WITH the otg usb cable connected, the start of eth0
fails. And after some other services fail due to a missing eth0 NFSd
catch the free fall of the kernel and goes into an endless waiting
loop.
I have no clue, what influence what in this case...what is the way
usb otg seems to influence the eth0.... ?
I would be very happy if some could shed some light on to this
miracle....???
Best regards,
mcc
freezes.
loop.
miracle....???
Strange, with that config/patchset. I usually have the bone powered
over 5V DC jack, with both the ethernet and usb-serial plugged in..
Robert Nelson <robertcnelson@gmail.com> [12-09-19 21:08]:
> Hi,
> freezes.
> loop.
> miracle....???
Robert Nelson
Hi Robert,
I am using the LCD7 with the Bone, which has a 5V jack, which also
feeds the Bone...
But with other kernels it works so the hardware seems to be ok...
Best regards,
mcc
> Hi,
> freezes.
> loop.
> miracle....???
Robert Nelson
Another bit of light:
When connecting the usb serial plug (ssh connection freezes) and
diconnecting is again (release of the ssh connection) dmesg prints:
[ 565.356781] gadget: high-speed config #1: CDC Ethernet (ECM)
[ 570.331298] musb g_ether gadget disconnected.
It seems, the Bone tries to open a second ethernet connection which
may explain why ssh stops working...
I inserted the modules usbserial and ti_usb_3410_5052 in beforehand...
(Additionally the touchscreen of the LCD7 seems not functional with
this kernel...)
Best regards,
mcc
> Hi,
> freezes.
> loop.
> miracle....???
Robert Nelson
Correct, with that config, the Bone tries to create a usb-gadget
ethernet connection.. But the evil ftdi usb-serial adapter is still on
the same usb bus..
this kernel...)
Don't remember off hand, where gentoo wants it, but in ubuntu/debian
we dump "fbcon and ti_tscadc" into /etc/modules, to fix the touchscreen..
