Hi mrne,
If you want I can send you the driver. I compile it on my host machine. (I would need your email address). Moreover don’t you think you should use opkg install rather than dpkg install. I don,t have BB with me right now but if its ok then the above error I found comes when there is some broken download or a download that conflicts with the packages already available. I also have a question, I have tried many times to boot the same image you are using but I did not have any luck. What did you do. Can you guide me in this. I am still using the demo image that comes with BB.
Ali
