I get an error when installing the drivers on Windows 64.
On Sun, 21 Oct 2018 07:51:32 -0700 (PDT), Historica
<damlar1803@gmail.com> declaimed the
following:
When I plugged in my BeagleBoard, I opened _Start.htm_ and installed
Windows64 driver. But the installation fail everytime I try.
  There is no "Windows64"... There are 32-bit and 64-bit versions of
Windows 7, 8, 8.1, and 10. Which do you have?
  Also, which "BeagleBoard" ("board" tends to get used for the really big
systems, "bone" is used for the more common credit-card sized units).
Does anyone know how to fix this ?
  Windows10 used to complain about unsigned drivers, but that was fixed
nearly two years ago (I think the OS is supposed to now find the driver via
M$ Plug&Play search -- no manual install needed).
  I'd suggest going into the device manager, looking for anything Beagle
related (or with a yellow ! marker) and in properties -- remove the driver.
Reboot to clear memory. Then connect and see if Windows attempts to install
drivers found on-line.
